why do I need alternator spacer for water pump on 69 ss 350 - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 25th, 09, 06:15 PM Thread Starter
Doug
Hey all. Have been looking at many pictures of different 69 SS 350 cars and noticed on some ( like my set up) there is a small spacer between the upper alternator bracket and the water pump. The upper bracket also mounts to the thermostat housing.
I have also seen pictures where there is no spacer used. I assume the no spacer is the correct way. My water pump is not original. It is a GM pump but more modern. Does anyone make a repo that is correct for my 69 Camaro SS.
Can someone please offer some info on the water pumps.
Thanks guys.
-Doug
Mr. Super Sport is offline
post #2 of 8 (permalink) Old Jan 25th, 09, 06:22 PM
NHBandit's Avatar
Re: why do I need alternator spacer for water pump on 69 ss 350
Thanks guys.
-Doug
There are lots of different water pump styles used over the years, a few different top alternator brackets, and some aftermarket aluminum intakes have the hole for the rear of the alternator bracket in the wrong location. All of these variables can make for some "interesting" modification being needed to get everything to line up.
NHBandit is offline
post #3 of 8 (permalink) Old Jan 25th, 09, 06:31 PM Thread Starter
Doug
Thanks Mark. Has the stock cast iron intake manifold and the stock upper alternator bracket.
-Doug
post #4 of 8 (permalink) Old Jan 25th, 09, 09:41 PM
Smile Re: why do I need alternator spacer for water pump on 69 ss 350
Is this the spacer you are referring too ?
TJS69 is offline
post #5 of 8 (permalink) Old Jan 25th, 09, 10:06 PM
Steps
Some brackets, where bolts to inlet manfold have sloted holes...I think the factory is??
My factory is stored way, right down the bottom, so forgive me for not checking
My aftermarket chome one is slotted.
The one before I cracked after about a yr, it wasnt slotted and I didnt use a spacer.
Steptoe is offline
post #6 of 8 (permalink) Old Jan 25th, 09, 10:24 PM
Send a message via AIM to RamAirDave
The new/GM/reman water pumps are kind of a one-size-fits-all, and come with that spacer for applications when needed.
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #7 of 8 (permalink) Old Jan 26th, 09, 02:14 AM
the long water pump came out in 68 in some cars, and 69 in everything but trucks. it was a nice and clean setup that is easy to work with.
they changed the upper alt mount for 76 for reasons only known to the GM engineers, and i think they also changed the PS pump mounting boss at that same time so they could use the overly complex mounting setup with 3 bolts to hold belt tension- one of which is behind the pump and almost impossible to get at.
then sometime in the early 80's they changed things again, and when they started using reverse rotation pumps in serpentine setups, they got rid of the alt and PS mounting bosses altogether, and some cars and trucks even got rid of the threaded hole for the heater hose.
if you go to NAPA or any decent parts store locally, you can get the correct pump for your year for about $40, and then hopefully you have the correct upper alt bracket to go with it. or you could just go find a later model upper alt bracket in the junkyard for a few bucks if you really want to get rid of that spacer.
you don't plan sincerity.
novaderrik is offline
post #8 of 8 (permalink) Old Jan 26th, 09, 07:12 AM Thread Starter
Doug
Thanks guys. I may see if i can track down an original 69 pump and see if it can be rebuilt. I appreciate your help.
-Doug
