Quadrajet metering rods - Team Camaro Tech
post #1 of 24 (permalink) Old Jan 26th, 09, 07:33 PM Thread Starter
Dan
I am rebuilding my 68 Quadrajet and after disassembly and cleaning noticed one of the secondary metering rod tips is bent. Is this a big problem? If so, where can I get new ones? The code stamped on them is AX and I'm having a lot of trouble finding them anywhere. Summit has AU,CC,CE,CH,CJ,CK,CL,DA,CP. Could I use one of those? Could I reuse my bent one?
'68 SS/RS 408 BB
"I don't know what the world may need
But a V-8 engine's a good start for me
Think I'll drive and find a place to be surly."
Surly is offline
post #2 of 24 (permalink) Old Jan 26th, 09, 08:01 PM
Paul
Re: Quadrajet metering rods
How bent is it? Like a ninety degree bend or ???
If you lived closer I'd give you some...I have a whole box of QJet parts that I don't use anymore.
Best of 1.55 - [email protected]
paulm is offline
post #3 of 24 (permalink) Old Jan 26th, 09, 08:12 PM Thread Starter
Dan
It's bent like 10 degrees. Maybe 1/32 over the last 3/16 of the tip.
'68 SS/RS 408 BB
Surly is offline
post #4 of 24 (permalink) Old Jan 26th, 09, 08:36 PM
Paul
Can you just bend it back? The primary rods are thin, they get tweaked every now and then but I would just roll them on a flat surface and straighten them back out...I mean as long as the tip isn't jacked up.
paulm is offline
post #5 of 24 (permalink) Old Jan 26th, 09, 09:24 PM Thread Starter
Dan
This is a secondary rod and can't be bent easily by hand.
'68 SS/RS 408 BB
Surly is offline
post #6 of 24 (permalink) Old Jan 27th, 09, 10:03 AM Thread Starter
Dan
I found this website: http://www.hioutput.com/tech/qjetrod.html and it looks like AX is the same as CJ and BB. CJ is available from Summit...
Should I use it? What's the difference, anyway?
'68 SS/RS 408 BB
Surly is offline
post #7 of 24 (permalink) Old Jan 27th, 09, 10:23 AM
Paul
What's the difference between rods? The taper and the diameter of the tip...it's all about how quickly the metering area changes and the final metering area (the amount of area that the gasoline can flow through...jet diameter - rod diameter).
When the rods are all the way down the fatter part of the rod is in the jet, allowing less space for the gasoline to flow through:
http://www.stratagaz.com/Quadrajet/1...s%20Cruise.jpg
When the rods are further out of the jets the smaller end of the rod is in the jet allowing more gasoline to flow through:
http://www.stratagaz.com/Quadrajet/1...Jets%20WOT.jpg
paulm is offline
post #8 of 24 (permalink) Old Jan 27th, 09, 10:52 AM
If you cannot straighten the rod and decide to use the CJ rod be sure to change both rods to keep it even.
It will not hurt to try the CJ rod and see if it works. They are super easy to change.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #9 of 24 (permalink) Old Jan 27th, 09, 07:37 PM
Charlie
The rods meter the fuel delivery to the secondaries at a given throttle angle. You have an "AX" on a stock carb? Have you had this since it was new? That seems a little on the rich side for a "stock" carb. The AX rod is what's known as a "L" rod. That means it reaches its rich stage at 70* of the throttle angle. The tip measures .0419" at 70* and tapers down to .0397" at 90* of throttle angle. It starts at .1339" at 0*. 0* is when the secondary throttle plates are opening, but the air valve has not started to open yet. For example, if you push the pedal almost to the floor and the secondaries open to merge in traffic or overtake someone, the air valve isn't opening, but the secondary plates are. What is the main jet and rod combo? In that particular grouping, the AX, CJ and BB all have the same exact metering.
67CamaroRS/SS is offline
post #10 of 24 (permalink) Old Jan 28th, 09, 09:41 AM Thread Starter
Dan
The main rods are 4B. I got this carb with the engine from a 68 Impala big block when I bought someone's project (He was moving). I've never run the carb in this or any other car. I'm going to make it a daily driver (maybe an occasional trip to the track), so do you have any recommendations for primary/secondary rods?
'68 SS/RS 408 BB
Surly is offline
post #11 of 24 (permalink) Old Jan 28th, 09, 10:07 AM
Paul
If you have never even tried the carb, here is a tuning approach:
http://www.corvetteclub.org.uk/files...une_a_qjet.pdf
paulm is offline
post #12 of 24 (permalink) Old Jan 28th, 09, 11:18 AM
Charlie
Q-Jets are emissions carbs and are designed to run on the EXACT engine it originally came on, but they can be modified to run on any engine. You are going to have to make some changes to the idle tubes, down channel restrictions, idle mixture screw holes, idle bypass air, main jet, upper and lower air bleeds and primary and secondary rods. I know this sounds like a lot, but these mods are easy to do and once they're done, the carb will out perform ANY carb on the street. I made the switch from an Edelbrock Thunder AVS 650 to a Q-Jet and have never looked back. It delivers more power/torque, better fuel economy and a better idle. The 1st thing people are going to asy is, "ditch the Q-Jet and get a Holley", but IMO, Holley's can't hold a stick to a properly tuned Q-Jet, both in power and MPG.
As far as a rod to suggest, we are going to need to know your specs. Cam size, etc. The carb settings are very specific depending on engine specs. You are going to need a full set of numbered drill bits(1-60 & 61-80).
post #13 of 24 (permalink) Old Jan 28th, 09, 11:23 AM
Paul
In addition to what's already been posted...you are going to have make sure that QJet is "Tip top" before you go changing stuff. If there are any issues with it you will lose your mind trying to dial it in.
paulm is offline
post #14 of 24 (permalink) Old Jan 28th, 09, 11:25 AM
Charlie
This is a great suggestion. I agree wholeheartidly. I highly suggest you start by rebuilding the carb and then we begin the modifications.
post #15 of 24 (permalink) Old Jan 28th, 09, 11:28 AM Thread Starter
Dan
This is the carb that came with the engine and the numbers on the carb indicate it may be the original. I tore the engine down, had it machined, and rebuilt it myself. The cam is a new one recommended by the engine shop, so would they be a good place to ask about appropriate rods, needles, etc?
'68 SS/RS 408 BB
Surly is offline
