Would this fuel injection unit be any good?? - Team Camaro Tech
post #1 of 17 (permalink) Old Jan 26th, 09, 07:43 PM Thread Starter
Travis
blackl78's Avatar
My friends.. Dads friend asked him to sell this setup for him. He is a older guy and didnt really know much about it. I took some pics and thought I would ask what you all thought about this unit.
The intake says holley on it , the computer is not from holley, I called and asked them. The injectors are bosch 24#. I called the company whos name is on the ECM and they said they didnt burn chips for that unit anymore, they do all LSX stuff now. This is in really nice shape, but is it outdated? I can probably buy it cheap enough and wouldnt even know what to offer for it??
I wondered if it would be any good to run on my 406 in my 67 camaro?
Thanks!
Travis
67 L78
67 Vert
blackl78 is offline
post #2 of 17 (permalink) Old Jan 26th, 09, 07:50 PM
Paul
Re: Would this fuel injection unit be any good??
I don't have a clue about Speartech, but...you could buy a Holley ECU and harness to drive that stuff.
Best of 1.55 - [email protected]
paulm is offline
post #3 of 17 (permalink) Old Jan 27th, 09, 06:08 AM Thread Starter
Travis
blackl78's Avatar
The guy from speartech said I could do it myself with a laptop, I know absolutly nothing about that! Im pretty sure that the 24# injectors wont be big enough for 450-500 hp. based on what I have read last night?? and if I want to go E85 fuel they will have to be even bigger? So when it comes to reworking/burning a chip for this thing Im lost.
I just dont want to spend good money on this and it bleed me dry trying to get it to work.
Travis
67 L78
67 Vert
blackl78 is offline
post #4 of 17 (permalink) Old Jan 27th, 09, 07:33 AM
Paul
Ummm, how long have you been "into" camaros? That is an unattainable goal my friend, LOL!
If you can program the thing yourself, cool but support is the key issue as there is always a learning curve when swapping to EFI. Yes, you'll need bigger injectors...30lb injectors helped propel my car to 11.90's. If you can use everything there the biggest hurdle will be getting fuel to it. You can find deals on EFI stuff, I just bought a set of used 42 lb injectors for $100. I saw a recent Ebay auction for a Holley MPFI setup bid to a little over $500 to kind of compare to what that system's worth.
paulm is offline
post #5 of 17 (permalink) Old Jan 27th, 09, 07:42 AM Thread Starter
Travis
blackl78's Avatar
Been messing with these cars for 26 years, How right you are!!
That helps a lot, I dont know where and how I would get any support on this?? Speartech allready said they arent doing these anymore. I dont want to buy a new ECM and harness...Im sure thats expensive. I would like to try FI because I think it would be better with E85 if I were to try and run it.
Thanks!
Travis
67 L78
67 Vert
blackl78 is offline
post #6 of 17 (permalink) Old Jan 27th, 09, 08:11 AM
Paul
I would pass unless you can get it dirt cheap...Keep your eyes out for a programmable/supported setup like Holley, Edelbrock or whatever. Times are tough right now and deals can be found!
paulm is offline
post #7 of 17 (permalink) Old Jan 27th, 09, 11:32 AM
Fred
Last time I did a mental total (the calculator hadn't been invented) the cash in my car (for everything, insurance too) was at about $35K. That was in 1972 I think.
128.79mph 1.428 60'
Fred Ficarra is offline
post #8 of 17 (permalink) Old Jan 27th, 09, 05:04 PM
Please consider doing this.
Buy it worth a good FAIR price and then contact somebody like Force Fuel Injection to see what they would charge you to set it up for you in again, for a FAIR price.
http://force-efi.com/
And please stress a FAIR PRICE in a nice manner so that they will know that you will drop them like a used rubber if you think they are bending you over!!
And I would have to do this myself IF I ever graduate from "Old-School"!!!
Inglese may be another place too!
pdq67
post #9 of 17 (permalink) Old Jan 27th, 09, 05:41 PM Thread Starter
Travis
blackl78's Avatar
pdq67
OK.... What do you think a FAIR price is to offer for this setup??
What do you think I will have invested by the time its all said and done?
Travis
67 L78
67 Vert
blackl78 is offline
post #10 of 17 (permalink) Old Jan 27th, 09, 05:48 PM
Vintage 68's Avatar
Is that intake for Pre-86 heads or 87-and later ???
Those center holes look a little 'verticle' for pre-86...
You can always go with a "MegaSquirt" system if you want to DIY and save a ton - MegaSquirt - http://www.megamanual.com/index.html
(edit) Here's a link to good info w/software links - http://home.earthlink.net/~dvgreimann/holleyefi.html
1968 Convertible
Some trucks
Vintage 68 is offline
post #11 of 17 (permalink) Old Jan 27th, 09, 06:01 PM Thread Starter
Travis
blackl78's Avatar
I think it is setup for both. I did look for that and the way its drilled looks like you could use it on either one.
Travis
67 L78
67 Vert
blackl78 is offline
post #12 of 17 (permalink) Old Jan 27th, 09, 07:07 PM
Bill
Travis,
How "cheap" can you get it for ?? I figure the intake isworth at least $100, Same for the throttle body/air valve. Injector rails ? Distributor probably $50 ?
A similar entire system from Holley is $2500 so if you can get it cheap, you will still be way ahead of the game even if you have to buy a ecu and injectors.
By the way, almost any decent system will have to be programmed with a laptop for final tuning in your car. If you dont feel comfortable with learning that, then maybe sticking with a carb is best.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #13 of 17 (permalink) Old Jan 27th, 09, 07:16 PM Thread Starter
Travis
blackl78's Avatar
Originally Posted by BillK View Post
Travis,
I have no idea yet what I can get it for, I kinda wanted to know what you guys thought it was worth first and then go there with cash--- listen to the asking price--- Then if its less I have the cash in hand and ifts more pull all the cash out and say "this is what I have to offer"
My son has a fairly new laptop and is pretty good with computers, I can follow instructions pretty well.. I think I would try the tunning for sure without much intimadation.
Travis
67 L78
67 Vert
blackl78 is offline
post #14 of 17 (permalink) Old Jan 27th, 09, 07:23 PM
Banned
Ron
Badbird's Avatar
Travis.....I think $500 would be a fair offer!
Badbird is offline
post #15 of 17 (permalink) Old Jan 27th, 09, 07:37 PM Thread Starter
Travis
blackl78's Avatar
OK, Thanks Ron thats what Im looking for.... That gives me a starting point.
Did you get my email?
Travis
67 L78
67 Vert
blackl78 is offline
