Crankshaft Timing Gear - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 27th, 09, 03:08 PM Thread Starter
Ben
Question Crankshaft Timing Gear
Im trying to pull the timing chain gear off the crank,its a complete short block assembeled . After finding a puller small enough to fit , it broke on of the bolts on the puller , probably just cheap bolts. Is there something Im missing here, or what??
Big Ben
1967 Camaro
1980 Z/28 all original
original owner
2011 2SS/RS Camaro 6speed/manual
BigBen is offline
post #2 of 5 (permalink) Old Jan 27th, 09, 04:22 PM
Re: Crankshaft Timing Gear
I probaly have 3 pullers that will work, the 4th is a chisel, and a wooden handel furd
torque wrench. Place chisel above keyway. Smack with furd tool it will split gear, check
sprocket carefully toss in trash.
john68 is offline
post #3 of 5 (permalink) Old Jan 27th, 09, 04:57 PM
I'd replace the bolts with Grade 8, if a jaw puller, and install the puller again and apply a good pull to it, then heat the sprocket - it may just 'pop' right off or move some, repeat.
Oxy/acetelyene torch works good for applying fast heat, MAPP gas next, and finally propane gas.
post #4 of 5 (permalink) Old Jan 27th, 09, 05:08 PM
I have always used my OTC 10" 2 jaw puller to pull these always making sure I have some type of bearing as a pilot in the crank bolt hole. Seems the longer jaw puller pull straighter where the smaller ones will slip if you don't have means of clamping the jaws.
Might try loading your pull and tapping the turn bolt with a hammer, to jar the sprocket. Go back with some anti-sieze.
TC # 349
zdld17 is offline
post #5 of 5 (permalink) Old Jan 27th, 09, 05:10 PM
Banned
Ron
Badbird's Avatar
If I'm not mistaken, me thinks I used a 6" gear puller to remove zee cranker sprocket!
Badbird is offline
