building engine - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 28th, 09, 12:38 PM Thread Starter
Vicente
Vinchenzo68cam's Avatar
building engine
have access to different engines that are torn up or otherwise not working. what do you all think about this hypothetical combo. using a good 350 andputting 283 heads on there. i think i got the combo right. feedback.....por favor.... for street use
VCan2-68'vert
68vert/3spd/base
78TA/400
81GMCstepside-streetcoupe
Vinchenzo68cam is offline
post #2 of 7 (permalink) Old Jan 28th, 09, 02:51 PM
BILL
SPARKY69's Avatar
Re: building engine
thatll be a good little torque motor... small intake runners with 58cc or 64 cc..done it before makes a killer lil street motor!!
SPARKY69 is offline
post #3 of 7 (permalink) Old Jan 28th, 09, 05:43 PM
Harley
wiskeesour's Avatar
Re: building engine
thatd run alright I guess. find some 388 heads and build a 383 and I think youd be happier.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #4 of 7 (permalink) Old Jan 29th, 09, 07:32 AM Thread Starter
Vicente
Re: building engine
Hey Harley, Didn't know that with the 388 heads would =383. I got some feelers out for those heads. I have a 350 w/ 283 heads on my camaro now. told it is like 305???
I have a 305 on my gmc stepside and want to overhaul but of course upgrade. any suggestions?
VCan2-68'vert
68vert/3spd/base
78TA/400
post #5 of 7 (permalink) Old Jan 29th, 09, 08:42 PM
Harley
wiskeesour's Avatar
Re: building engine
...sent you a pm
Thanks Chief.
post #6 of 7 (permalink) Old Jan 30th, 09, 06:45 AM
Shawn
Re: building engine
what?
head size has nothing to do with the CI of the engine
CI is calculated by taking the bore of the engine times the stroke:
bore x bore x stroke x .7854 x 8 will give you the CI of a v8 engine
lets do a 302:
4 x 4 x 3 x .7854 x 8= 301.6 ci
edit* a 383 is a bored engine .030 over, with a 400 crank
4.030 x 4.030 x 3.75 x .7854 x 8= 382.66 ci
you can put 302 heads on it, 327 heads, or 350 heads and its not going to change a thing, other than the compression ratio
victimizati0n is offline
post #7 of 7 (permalink) Old Jan 30th, 09, 10:31 AM
Jerry
Re: building engine
While it sounds neat on paper, I think you would be disappointed. I would guess that a set of over the counter Vortec heads would make at least 20% more horsepower than the very best stock 283 heads you could find.
69 Z11 03D Van Nuys
82 Z28 Gordon Johncock's Pace Car
97 30th Z28 6 speed vert 1 of 175
69 z11 is offline
