Eng from jegs - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 29th, 09, 08:38 AM Thread Starter
dan
danimaldds's Avatar
Eng from jegs
What do you guys think of this? Will it fit on a 69 ss or a 64 vette?
http://www.jegs.com/i/Blueprint+Engi...0CTC1/10002/-1
Dan
1969 SS 383 Stroker , TKO 600, 3:73
1964 vette conv. 327/ 300 freshly ,completely repainted. I mean everything!
danimaldds is offline
post #2 of 11 (permalink) Old Jan 29th, 09, 08:46 AM
Chad
67 Plum's Avatar
Re: Eng from jegs
The one piece rear main could be a problem if you have a standard shift car.The passenger side dipstick could be an issue also.
67 Plum is offline
post #3 of 11 (permalink) Old Jan 29th, 09, 09:17 AM Thread Starter
dan
danimaldds's Avatar
Re: Eng from jegs
why and why?
Dan
post #4 of 11 (permalink) Old Jan 29th, 09, 09:28 AM
Re: Eng from jegs
One piece seal requires a different flywheel because of the smaller bolt pattern on the flange.
Pass side dipstick would be a clearance problem if A/C equipped, evap suitcase might be in the way for a '69.
Everett#2390 is online now
post #5 of 11 (permalink) Old Jan 29th, 09, 09:40 AM Thread Starter
dan
danimaldds's Avatar
Re: Eng from jegs
new flywheel is no prob, I thingk. No air. But what about the motor itself. It's a good deal yes?
Dan
post #6 of 11 (permalink) Old Jan 29th, 09, 03:35 PM
68Camaro68's Avatar
Re: Eng from jegs
I have the 350 they sell over 2 years and couldn't be more pleased with it. I have done several runs down the drag strip, 4 laps wide open around Pocono and countless car shows. You can order direct from them like I did. I got the block painted the color I wanted and the dip stick on the side I wanted with no extra cost. A lot of people say get local in case you have a problem. I say, if it was done right you shouldn't have a problem.
http://www.blueprintengines.com/imag...968camaro3.jpg
68Camaro68 is offline
post #7 of 11 (permalink) Old Jan 29th, 09, 05:13 PM
T
Re: Eng from jegs
I had been looking at the Blueprint engines and when looking around, I didn't see anyone who had an issue with them. I STILL haven't gotten around to my engine upgrade, so I can't comment on how good their stuff is.
Scott (aka BonzoHansen) had posted that RockAuto also carries the blueprint engines and at one point had a better price (I think RockAuto also has various online coupons and stuff if you search around) Here was that thread:
https://www.camaros.net/forums/showthread.php?t=120077
As mentioned, there are definitely benefits in "going local" with a builder if you have any issues, etc. But I hadn't seen any negative comments on Blueprint, don't think they'd be that bad...
TMessick is offline
post #8 of 11 (permalink) Old Jan 29th, 09, 09:05 PM
Jason
Re: Eng from jegs
Got the E-mail newsletter from Jegs today and it looks like they are running a special on that engine for $2995. Not a bad price for a turnkey engine with that hp and torque.
jjbaldw is offline
post #9 of 11 (permalink) Old Jan 29th, 09, 09:28 PM
AJ
Re: Eng from jegs
I was surprised to see as much power as it makes with quite a large cam and a compression ratio that does not really match.
But with crate engines today very seldom do you see one with over 10:1 advertised as a street motor just so the companies can push more out the door.
People are so set now a days that anything over 9:1 needs race fuel or it will explode.
I'm the type that likes a lot of compression unless it's forced induction so I am a pretty biased person to post.
In my honest opinion for the price it's a great buy, you should have no probs with reliabiltity, street ability or smokin' what ever punk kid is next to you.
I have seen a few pretty hard core blue print engines so they must be good.
for 4k I don't think you could build it and achieve the same power. Seems like a good by.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #10 of 11 (permalink) Old Jan 29th, 09, 10:38 PM
Re: Eng from jegs
Can you email the link to the $2995 price, when I check the site it is listed at $3995.99? Thanks
Black Z is offline
post #11 of 11 (permalink) Old Jan 30th, 09, 09:34 AM Thread Starter
dan
danimaldds's Avatar
Re: Eng from jegs
That's not the turn key. it's more like $3995 but, still I bought racing 4 cyl for 6k. and they weren't blue printed.
http://www.jegs.com/p/Blueprint+Engines/761056/10002/-1.
My other question is will it fit in a 327 corvette (64)??? Found out from Jegs. probably not due to the height of the manifold.:-(. Still a good deal with a 30 month warranty. Dipstick can go on either side. starter parallel bolt pattern is ok and a new flywheel is $80..I want this to save the original motor in the 69 camaro.
Dan
