whats a good fitting header for a 69 z28 - Team Camaro Tech
post #1 of 18 (permalink) Old Jan 29th, 09, 09:06 PM Thread Starter
richard
z28rich's Avatar
I want to put a new set of headers on my z,but whats the best fitting ones.I have a set of hookers now and they suck
1969 Garnet Red Z/28-RS with Black stripes
and Black Deluxe Int. I found my build sheet
2012 Shelby SVTPP GT500 race red with dash signed by Caroll Shelby
RIP Mr Shelby
z28rich is offline
post #2 of 18 (permalink) Old Jan 30th, 09, 05:19 AM
Re: whats a good fitting header for a 69 z28
I just got a set of Dyna Tech headers for my 67. I installed ny engine last week end and put the headers on just to see and they fit perfect,plenty of clearance with the steering box and did not hang below the sub frame. I tried to remove plugs and that was not a problem even with the angle plug AFR's i have. I used thier steped headers and went with the 1 3/4 to 1 7/8 primary tubes with 3" colectors. The fitment and finish were geat i am very happy. Mike
mike's blue67 is offline
post #3 of 18 (permalink) Old Jan 30th, 09, 05:43 AM
I just removed a 3 year old set of TriY's that fit great on AFR heads. I went to larger heads that required a larger exhaust port header, went to Dougs D368. Both of these are long tube headers and fit very well.
TC # 349
zdld17 is offline
post #4 of 18 (permalink) Old Jan 30th, 09, 08:34 AM
I have heddman coated 15/8 full length headers. they fit good and clear my manual steering box by about 1/4 inch. Never had any leaks and they've been on for 5 years now. They are in a 69z with a vortec headed 350 and a mucie 4 speed. I had to reverse the clutch pedal return spring so that it could be used, but it works.
Dave69Z is offline
post #5 of 18 (permalink) Old Jan 30th, 09, 11:15 PM
Andy
Send a message via AIM to 67SS&99SS
agreed!
1967 Camaro SS: 406 sbc, 522hp/514 ft lbs, Doug's 1 3/4" headers, M20, posi, 3.73's, vintage air gen IV, IROC steering box, Comp Eng. weld-in sfc's & traction bars, chrome US Mags
67SS&99SS is offline
post #6 of 18 (permalink) Old Jan 31st, 09, 02:34 AM
if it's a true Z with the proper 302/350 mount setup, then Hedmans will fit.
if it is a clone-umm, i mean tribute- with 307/327 mounts, then Dynomax headers will fit.
it's easy to tell which mounts you have- the 302/350 mounts will put the stock distributor about an inch away from the firewall, and the 307/327 mounts will have a couple of inches back there.
you don't plan sincerity.
novaderrik is offline
post #7 of 18 (permalink) Old Jan 31st, 09, 09:51 AM
Shawn
what would be be like with an HEI?
my firewall was smashed in with a hammer to fit it in there
victimizati0n is offline
post #8 of 18 (permalink) Old Jan 31st, 09, 10:06 AM
BILL
SPARKY69's Avatar
YUP THOSE ARE GOOD
SPARKY69 is offline
post #9 of 18 (permalink) Old Jan 31st, 09, 01:11 PM Thread Starter
richard
z28rich's Avatar
I talked to the guys at dynatech and he said they have a header that works with no problems.he told me to use 1 3/4-1 7/8 header for the 302
Richard
RIP Mr Shelby
z28rich is offline
post #10 of 18 (permalink) Old Jan 31st, 09, 03:16 PM
I dont know about the 1 3/4 to 1 7/8 on a 302. I would go with the smaller 1 5/8 to 1 3/4 to try and keep some tourqe on the lower end since the dont have much any way below 4500 rpm. I use the larger on a 406 with 520 HP and 525 ft lbs of tourqe so i had plenty down low. I thought about keeping it small untill i measured my exhaust ports and they were a hare larger the 1 5/8 so thats why i went with the larger. My Dyna tech's fit great. No issues at all. Let me know how it goes.
post #11 of 18 (permalink) Old Jan 31st, 09, 03:55 PM Thread Starter
richard
z28rich's Avatar
Mike,is your car a auto or stick?
RIP Mr Shelby
z28rich is offline
post #12 of 18 (permalink) Old Jan 31st, 09, 04:10 PM
I think 1 3/4 or 1 7/8" primary tubes on a 302 is an over kill unless you have all the good stuff and run motor at 8500 all day long and wear a funny looking hat or from Malvern, Pa.
Go for the smaller tubes for street or show.
TC # 349
zdld17 is offline
post #13 of 18 (permalink) Old Jan 31st, 09, 04:45 PM
chris
This thread may help: https://www.camaros.net/forums/showth...hlight=thorley
4sspd69 is offline
post #14 of 18 (permalink) Old Feb 1st, 09, 07:53 AM
Rich, my car is a speed now, iam in the middle of converting it to a 5 speed.
post #15 of 18 (permalink) Old Feb 1st, 09, 01:24 PM
then you have the 302/350 mounts.
