Heads/cam question - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 30th, 09, 05:21 AM Thread Starter
Heads/cam question
I purchased a 350 about a year ago from the Carolina Rod shop (they did not build the motor) with about 500 miles on it. When asked how much HP it was putting out, the answer was, about 300. I dont know much about the motor other than it has double hump heads. It doesn't lope like it has a big cam. My question is.....what is a good head/cam combo to put on this motor for increased HP. What is a reasonable Hp expectation with said package?
Thanks,
bnbpaintballer is offline
post #2 of 12 (permalink) Old Jan 30th, 09, 06:40 AM
Shawn
Re: Heads/cam question
first off, we need to know what you're using the car for
victimizati0n is offline
post #3 of 12 (permalink) Old Jan 30th, 09, 08:10 AM
Thumbs up Re: Heads/cam question
Please don't forget that the great old L-48, 295/300hp/350 engines are fantastic DD's. Suckers are right at 10 to 1 CR'd!!
Pull the old -929 cam and install a VooDoo 268 or whatever cam that's from 268/270/272 and add a cheap set of 4-tube, long headers and go have more fun than John Law will allow!
pdq67
post #4 of 12 (permalink) Old Jan 30th, 09, 05:48 PM Thread Starter
It will be a weekend car, with little to no track time. However, I would like it to have plenty of umph. It does have a set of hooker headers also.
post #5 of 12 (permalink) Old Jan 30th, 09, 06:44 PM
afr 195s H-R 235*-245* at .050 no more than .500 lift 400-450 HP ? keep us posted Doug.
ssdoug is offline
post #6 of 12 (permalink) Old Jan 30th, 09, 07:59 PM Thread Starter
I see these are 65cc and 75cc. What would I need?
post #7 of 12 (permalink) Old Jan 31st, 09, 02:39 PM
Joe A
If you want GOOD advice then listen to pdq67. I did and I have a kicken 355 @ 400 hp with a 268 cam good heads and a LOT of machine work. The key is... what tranny and gears do you have behind it. More info...
1967 SS 350 Clone ( not hiding it )
Never Ending Project
camjoe63 is offline
post #8 of 12 (permalink) Old Jan 31st, 09, 05:31 PM Thread Starter
700r4, 12 bolt 373 posi.
post #9 of 12 (permalink) Old Feb 24th, 09, 06:53 PM
Ken
I'm curious as to how the Voodoo 268 sounds at idle. I am lookng at getting this Cam with Edelbrock RPM heads. My motor is being balacned as we speak.
Feedback on the sound?
CamFrk68 is offline
post #10 of 12 (permalink) Old Feb 24th, 09, 07:28 PM
Bill
Brian,
First thing you should do is spend a few bucks and have your car put on a chassis dyno for a couple of runs. That way you will know what you have now as far as power goes. Without a baseline, it is impossible to make a good plan for improvements.
Just my opinion,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #11 of 12 (permalink) Old Feb 26th, 09, 08:26 AM
Chris
I don't have any sound clips, but I have the VooDoo 268 in my 355 with 64cc RPM heads and intake, 600 cfm carb, 1 5/8 headers. Motor is just slightly over 10:1 compression. I'm running a M-21 and 4:10 rear. The cam sounds excellent and performs even better. Nice agressive lope and has great street manners. I'm experimenting with a 4-hole carb spacer to see if it builds a bit more low-end grunt.
Overall, a great cam choice for a street motor with at least 9.5:1 compression, good flowing heads with a 200cc & lower intake runner, high-rise dual plane intake and steep rear gears. Roller cams are much better, but I was on a budget.
1969 Camaro
Electric Blue Lacquer Paint
355/400 HP, M-21 4-Speed, 8.5 10-Bolt 4:11 Posi
Cal69 is offline
post #12 of 12 (permalink) Old Feb 26th, 09, 09:15 AM
Talking Re: Heads/cam question
You want 64 or 65 cc heads to keep your compression ratio up. This should still be pump gas friendly.
TJS69 is offline
