Calculating CID - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 12th, 09, 10:08 PM Thread Starter
Louie
rad454's Avatar
Calculating CID
Gentlemen,
My engine builder punched my 454 out .040 over. What CID doe's this make the engine?
Also, is there a generic formula for calculating this?
Mahalo in advance.
rad454 is offline
post #2 of 7 (permalink) Old Mar 12th, 09, 10:40 PM
Re: Calculating CID
Dam guy, get your old math book out and figure how big it is!
BUT I figure very close off the top of my head, a 462 or so??
pdq67
post #3 of 7 (permalink) Old Mar 12th, 09, 11:07 PM
Jeff
Re: Calculating CID
Originally Posted by rad454 View Post
Gentlemen,
Mahalo in advance.
Bore area * stroke * number of cylinders.
Bore area = pi (3.14) * (radius of bore)^2
For example, I have a 327. That's a 4" bore (2" radius) and 3.25" stroke.
Bore area = 3.14*(2)^2 = 12.56 sq. in.
Multiply that by the stroke = 12.56 sq. in. * 3.25 in. = 40.82 cu. in. per cylinder
Multiply by 8 = 326.56 or "327"
If I remember correctly, your 454 would have had a 4.25" bore and a 4" stroke.
3.14((2.125)^2) = 14.1790625 sq. in.
14.1690625(4) = 56.71625 cu. in./cylinder
56.71625(8) = 453.73 or "454"
So plug in your new bore and re-calculate:
3.14((2.145)^2) = 14.4472185 sq. in.
Answer(4) = 57.788874 cu. in./cylinder
Answer(8) = 462.310992
Good job pdq!
jkaufman is offline
post #4 of 7 (permalink) Old Mar 13th, 09, 05:39 AM
Re: Calculating CID
An even easier way!!
(bore squared) X stroke X .7854 X number of cylinders = CID
BPOS is offline
post #5 of 7 (permalink) Old Mar 13th, 09, 08:25 AM Thread Starter
Louie
rad454's Avatar
Re: Calculating CID
Jkaufman,
When I asked my engine builder how to make more power and maintane streetability he simply said, (with a rather dull look on his face) "when in doubt, bore it out."
You and our Physicist would get along great. That is probably the most well thought out technical answer in the whole Team Camaro website.
Thx
rad454
rad454 is offline
post #6 of 7 (permalink) Old Mar 13th, 09, 09:32 AM
Re: Calculating CID
Kindda the only way to figure the volume.
Al's formula is a derivative of the original formula, I think.
post #7 of 7 (permalink) Old Mar 13th, 09, 11:54 AM
Jeff
Re: Calculating CID
True enough, Al. You can square the bore and take 1/4 of pi. That is indeed the same formula (actually a tiny bit more accurate, because it takes pi out to 4 decimal places instead of what I did: 2 decimal places). That's probably easier for everyone anyways, because then you don't have to divide your bore by 2 to get the radius. Just gotta remember the 0.7854 (pi/4). Thanks!
Glad you liked it, Louie!
jkaufman is offline
