Fluid on top of intake - Team Camaro Tech
post #1 of 32 (permalink) Old Mar 12th, 09, 10:14 PM Thread Starter
Jeff
I have a 1967 327/210.
What could be causing this pooling on top of the intake?
jkaufman is offline
post #2 of 32 (permalink) Old Mar 12th, 09, 10:23 PM
Re: Fluid on top of intake
Valve cover gaskets.
deerhunter is offline
post #3 of 32 (permalink) Old Mar 12th, 09, 10:36 PM Thread Starter
Jeff
That's what I was afraid of. When I first got the car, I had my mechanic do some suspension work and while he was at it, I just had him replace the valve cover gaskets since they were leaking. No wonder I have been searching for a new mechanic... He was even supposed to have used the non-paper type... I forget what they are called...*sigh*
jkaufman is offline
post #4 of 32 (permalink) Old Mar 13th, 09, 04:36 AM
Ken
I'd take a can of brake cleaner and clean it up real good and dry then run her a bit and check real good as to where the fluid is leaking from. You're probably right about the gaskets but this would tell you for sure and with only a 10 min. investment of time. Good Luck!
Ken
Ken Packard is offline
post #5 of 32 (permalink) Old Mar 13th, 09, 05:07 AM
The oil is wicking up thru the intake bolts, remove them clean with brake clean, use
teflon thread sealer on the bolt threads and retighten.
john68 is offline
post #6 of 32 (permalink) Old Mar 13th, 09, 05:13 AM
Patrick
This is where it is coming from. Do exactly what John said just to the two middle bolts.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #7 of 32 (permalink) Old Mar 13th, 09, 05:30 AM
1st 67 SS/RS's Avatar
I have the same problem. I thought the carb might be leaking. I replaced the gasket and cleaned around the carb but it still puddled up there. It is like a mix of fuel and oil. thanks for the pics and the fix.
67 Vert RS/SS 350 4 SP
1st 67 SS/RS is offline
post #8 of 32 (permalink) Old Mar 13th, 09, 01:12 PM
Banned
Ron
Badbird's Avatar
I don't know man but it appears that the flanges on the valve covers are warped or bent and new gaskets will not seal it up!.....Probably time for a nice new pair of valve covers!
Badbird is offline
post #9 of 32 (permalink) Old Mar 13th, 09, 01:23 PM
X4 or whatever the count is up to.
post #10 of 32 (permalink) Old Mar 13th, 09, 02:12 PM Thread Starter
Jeff
Thanks! I will try removing and re-installing those four bolts as instructed. Hopefully that fixes it. Being completely original, I'd rather not have to replace the valve covers. Does it have to be teflon thread sealer or can it be plumber's putty? If it should be teflon thread sealer, I will just pick some up on the way home from work.
jkaufman is offline
post #11 of 32 (permalink) Old Mar 13th, 09, 02:29 PM
I would rather see teflon thread sealer, If you have teflon tape several wraps can work.
If you are talking about plummers putty for sealing a foset to the sink NO, If plumers
putty for pipe seals it will probally work,
john
john68 is offline
post #12 of 32 (permalink) Old Mar 13th, 09, 02:43 PM
DjD
DjD's Avatar
I would use this stuff...
...Dennis
DjD is offline
post #13 of 32 (permalink) Old Mar 13th, 09, 02:47 PM
Paul
You may be able to just replace the valve cover gaskets...that's easy enough. You could even get a set of the "doubled up" cork gaskets...they could help seal if they valve covers are a little tweaked.
Best of 1.55 - [email protected]
paulm is offline
post #14 of 32 (permalink) Old Mar 13th, 09, 03:00 PM
I've got this problem too and so does my neighbor with a '68. I say intake bolts wicking.
Melrose RS is offline
post #15 of 32 (permalink) Old Mar 13th, 09, 03:11 PM
Ed
BigBlock1969RS's Avatar
That is good stuff, definitely recommended.
Ed
BigBlock1969RS is offline
