3890462 Heads - Team Camaro Tech
post #1 of 24 (permalink) Old Mar 13th, 09, 02:38 PM Thread Starter
Jeff
3890462 Heads
I have found a guy with a couple virgin sets of 3890462 heads. So, they have never been re-worked, ported, machined, etc. They are both 1.94/1.50 heads. They both came off a block to which they were originally installed back in late 1966. Is there anything that you guys see that would give cause to be cautious about purchasing or just turn away all together?
Here is the first set with their matching spreadbore intake:
Here are the close-ups on the intake:
jkaufman is offline
post #2 of 24 (permalink) Old Mar 13th, 09, 02:40 PM Thread Starter
Jeff
Re: 3890462 Heads
And here is the second set of heads (with matching date casts):
Questions, comments? I plan on having a shop disassemble, clean, hot-tank, and re-assemble for $68 per head (unless I find another shop that will do it for less and is reputable).
The guy is asking for $300 for the first set (whether I take the intake or not - intake is priced at $100) and $350 for the matching-date set. Are these fair prices? Again, all the parts are virgin and he says there is no damage, cracks, warping, etc.
Thanks!
jkaufman is offline
post #3 of 24 (permalink) Old Mar 13th, 09, 02:42 PM Thread Starter
Jeff
Re: 3890462 Heads
By the way, he will include the rockers on whichever set I choose, even though they are not shown on the first set.
jkaufman is offline
post #4 of 24 (permalink) Old Mar 13th, 09, 03:44 PM
Brandon
Re: 3890462 Heads
If you like feulie heads or if your looking for them to date correct your motor then they are worth it. I was fortunate when I got mine that the guy selling them didnt know what they were and I picked up a dated pair for $120.
Brandon J. licence 1NASTY67
Nantooch is offline
post #5 of 24 (permalink) Old Mar 13th, 09, 03:52 PM Thread Starter
Jeff
Re: 3890462 Heads
Yeah, I have a 327/210 and am looking to upgrade it to the 327/275 version (or as close as possible) while keeping it period correct. Do they look pretty standard, though? Nothing that screams "run away" when you see the shots? $120 is a great deal! Nice find!
jkaufman is offline
post #6 of 24 (permalink) Old Mar 13th, 09, 06:18 PM
Talking Re: 3890462 Heads
There are no accessory bolt holes in the ends of those heads. The double hump (camel backs or fuelie heads) were great in the 60's and 70's, but there are much better heads on the market now. If your car is a '67 or '68 then you do not need accessory holes, unless your car is not original. Those heads only have 160 cc intake ports. This is fine on a 327 or a 350. On a 383 or 400, you will want bigger !
TJS69 is online now
post #7 of 24 (permalink) Old Mar 13th, 09, 06:20 PM
Joe A
Re: 3890462 Heads
I have a set of those that had some serious machine work done to them. I have a vid clip of my engine running in my photobucket account with those heads and I like um.
1967 SS 350 Clone ( not hiding it )
Never Ending Project
camjoe63 is offline
post #8 of 24 (permalink) Old Mar 13th, 09, 10:06 PM
No offense Joe... that is what you have to do to them, to get them to work. A set of RHS Pro-Action heads will out perform those, at less money !
TJS69 is online now
post #9 of 24 (permalink) Old Mar 14th, 09, 12:59 AM Thread Starter
Jeff
Re: 3890462 Heads
I understand there are better heads out there, but I am going for a period correct car.
So, Joe, what kind of "serious" machine work was needed and why? Was the work performed to make them perform better or was there damage or warping that needed to be fixed? Did you harden the valve seats or open them up and de-shroud it?
jkaufman is offline
post #10 of 24 (permalink) Old Mar 14th, 09, 01:01 AM
Ron
Re: 3890462 Heads
That's a 66- 67 Turbo Flow Head with the Semi Open 64 cc Chamber or known as the Fuelie Head which were slightly different with a Closed Chamber 60cc chamber. Like the 68 Turbo Flow 291 casting it has no Accessory Hole but it's a simple matter of drilling a tapping as the casting is strong enough to support the alternator bolt.
These were Grumpy Jenkin's favoured heads and YES with a lot of work and "know how" can be made to Perform with the BEST; however the cost of machining today along with the lost art does not make it worth the price as you can bolt on Vortec or spend more and buy AFR's.
If you want originality or Ruled to compete with Stock Engines; as per Grumpy, then there is simply no other better LT1 SBC head.
Simply installing 2.02's /1.6 Valves and machine for guide plates can net you the stock 360Hp and 6500 rpm using a Solid FT 30/30 cam providing you have 10.5 to 11:1 Compression.
Grumpy could get them heads to flow well over 8000rpm.
By the way that Intake is favoured by Circle Track Racers who have to compete with Stock Intake Manifolds and Carbs.
This was my 70 1/2 Z28
Z15CAM is offline
post #11 of 24 (permalink) Old Mar 14th, 09, 01:10 AM Thread Starter
Jeff
Re: 3890462 Heads
Well, I have a 1967 327/210 with an all-original drivetrain. Right, it is the 64cc chamber with 1.94 intake and 1.50 exhaust. Being a 67, my car has no need for any accessory holes. Again, I don't necessarily want it to perform with the best. I just want them to perform as they were originally designed. Down the road, if I REALLY wanted to, I could always perform the work on them, but I doubt that will be in the future. I'm not a speed freak (believe it or not... and I'm 26 ). I really am just looking to do a period correct car and would like some advice from those with experience as to whether or not there is something obvious (that I'm not noticing) in these pictures that should make me turn and run...
jkaufman is offline
post #12 of 24 (permalink) Old Mar 14th, 09, 01:14 AM
Ron
Re: 3890462 Heads
You got it right then ;o)
Z15CAM is offline
post #13 of 24 (permalink) Old Mar 14th, 09, 09:51 AM
Smile Re: 3890462 Heads
Install everything and you will have a 275hp/327.
And install them w/ .020" thick steel shim headgaskets too.
It won't be correct for a stock 300hp/327 b/c they had the AFB carb on them..
pdq67
post #14 of 24 (permalink) Old Mar 14th, 09, 10:07 AM
Joe A
Re: 3890462 Heads
"So, Joe, what kind of "serious" machine work was needed and why?"
I had mine milled/decked for straightness, then had all new guides replaced, Hardened seats. Then I had the (exhaust valves only) increased, A circle track trick to make them push the exhaust gases out faster. I now have 1.94 intakes and 1.6 exhausts. No reason to go big on the intake because of the size of the runners. Then I had screw in studs, guides then I polished the intake runners. I figured I spent over $600 for the machine work alone. I had my machine shop match my heads to what I was putting on the bottom end of the block.
Yes as other have and had commented on the cost of doing machine work on these heads vs. buying new ones that flow better I went with a "period correct" head for my 67 ss350.
I say to each his own is what I go by and FWIW. I don't care for
Aluminum heads on street applications. Not with today’s fuel and also the climate you live in.
camjoe63 is offline
post #15 of 24 (permalink) Old Mar 14th, 09, 10:14 AM
Brandon
Re: 3890462 Heads
Jeff,
I enjoy mine. They may not be AFR's or Brodix or one of the other top sets, but they move the little mouse well with a good cam. I had mine fitted for the 2.02 1.60 valves. Machine shop told me that there wasn't a need to go to the hardend seats as long as I wasn't planning to use the motor to tow with. Cars been together now for nearly 6 years minus a cam swap do to a locked up lifter. Gets decent milage and still spins the tires when I feel like it.
Nantooch is offline
