which is worse? - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 13th, 09, 07:22 PM Thread Starter
scblucam's Avatar
which is worse?
Which is worse? A half point too much compression or .010 to .005 too little quench?
scblucam is offline
post #2 of 4 (permalink) Old Mar 13th, 09, 07:57 PM
Harley
wiskeesour's Avatar
Re: which is worse?
hmm...
If you have an ALKY motor, too much quench is a ngative thing...altho not entirely bad.
If you have a propane motor, not enough compression is a negaive thing...altho not bad.
Assuming you have a gas motor, with aluminum heads, 11.25:1 is pushing it on a perfect tune....and Ive seen 25 quench on an 8.5:1 motor.
Does this help? you can run upto 25 quench on the street if you have the chambers contoured and the pistons cut right. You cant have too much compression cause you can add more octane.
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #3 of 4 (permalink) Old Mar 13th, 09, 08:32 PM
DjD
DjD's Avatar
Re: which is worse?
Give an example of what you mean. Less quench in effect is more compression. As well typically more compression is more performance so can we assume this relates to pump gas?
...Dennis
DjD is offline
post #4 of 4 (permalink) Old Mar 13th, 09, 09:13 PM
Re: which is worse?
Up to the point of piston rock deck flat kiss of the head, you will be fine b/c you can always add octane.
pdq67
