comp cam 305h - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 14th, 09, 11:04 AM Thread Starter
comp cam 305h
Hey guys, i currently have a 67 camaro with a 383 engine and 10.5 cr, it has dart 215cc heads and rpm airgap intake with comp cams 280h. Im thinking of swapping to the comp 305h. It will be mainly driven on the streets and just on the weekends. it also has a th350 trans. What do yall think of this combo? Thanks
gsmith is offline
post #2 of 5 (permalink) Old Mar 14th, 09, 11:43 AM
Brandon
Re: comp cam 305h
I'm sure it will scoot along with the required 3500 stall, but why not just go to 1.6 roller rockers instead with the cam you have. That would bump your lift to .512 with less hassle and less chance of leaks.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 5 (permalink) Old Mar 14th, 09, 06:32 PM
Re: comp cam 305h
I want you to hunt up the link to the old article, "The Lash Word" and read it here.
Heck, here is it's link!!
http://www.72chevelle.com/lashword.htm
BB info but to me, it still applies to SB engines! And, imho, a 305 cam really will like about 12 to 1 CR.
pdq67
post #4 of 5 (permalink) Old Mar 15th, 09, 08:07 AM
Re: comp cam 305h
I ran the 280H in my 406 for years...ran great. 12.3 @ 110
I would recommend that you check your piston to valve clearance before you take that step. Also, using just as a street ride it will suck... very low vacuum,loading up,fouling plugs, and ect. It could work...but at a cost.
68 Camaro~LSx ~all motor
post #5 of 5 (permalink) Old Mar 15th, 09, 01:48 PM
AJ
Re: comp cam 305h
305H is way too big even for a 10.5:1 383.
If you had 12:1 I would say other wise.
If you really want to switch cams that bad just throw in a 286H or a 292H
The 286H is great for street and there when you put your foot in it, and it has a desirable idle. 1.6 rockers would work well too.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
