Carburetor Rebuild - Team Camaro Tech
post #1 of 16 (permalink) Old Mar 15th, 09, 03:14 PM Thread Starter
Jeff
Carburetor Rebuild
My dad and I disassembled my 2GV carburetor last night and I have a question. The choke butterfly was staked on one side (the accelerator side) and we filed the staking off. What do we do upon re-assembly? Do we solder the end or what?
jkaufman is offline
post #2 of 16 (permalink) Old Mar 15th, 09, 04:04 PM
Brandon
Re: Carburetor Rebuild
Jeff as a rule you wouldn't touch the butterflies at all. Now you'll have to braise it back on to the post it was attatched to with a fine torch.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 16 (permalink) Old Mar 15th, 09, 09:27 PM Thread Starter
Jeff
Not the butterflies in the throttle body... the big choke one at the top of the bowl cover. I'll upload a picture in a little bit to show you what I mean.
jkaufman is offline
post #4 of 16 (permalink) Old Mar 16th, 09, 10:55 AM
Brandon
Those are what I'm talking about. The butterflies in the throttle body are held in with screws.
Nantooch is offline
post #5 of 16 (permalink) Old Mar 17th, 09, 11:20 AM Thread Starter
Jeff
Yeah, I realized after I had disassembled the carb that I didn't need to remove that staking and the parts underneath it. Oh well, I got it back on without too much trouble.
So, it's all together and got it back on the car and tuned up yesterday evening after work. I have a slight issue, though. When driving, starting from a stop, the engine stumbles VERY slightly as soon as I tip into the accelerator (whether lightly or heavily, it stumbles the same). Anyone have any ideas as to what would be causing this?
Everything else runs very smoothly and it does not stumble any other time. If I am moving and tip into the accelerator, it does not stumble - probably because it's not from idle. Timing is dead on. Dwell is right where I want it (28). All cylinders are firing.
jkaufman is offline
post #6 of 16 (permalink) Old Mar 17th, 09, 12:04 PM
Vintage 68's Avatar
First, recheck float level - low level can cause this.
The 'fill slot' for the pump does not get enough fule spilling in to give a good refill and shot.
Taking for granted the new pump assembly was the same length, usless you just replaced the rubber plunger seal, and there is not to much play in the accelerator pump linkage...
Recheck the Pump Linkage adjustment to be sure it is moving the pump as soon as you start to open the throttle - you can bend the 'pump rod' (between the throttle lever and the pump lever) so it is a bit longer (think 'taking out the bend slightly) and it actuates the pump a bit sooner.
The only other item in this system that can effect this is the condition and type of pump check-ball and the spring system.
You removed this to clean (didn't you?) and there was a replacement ball in the renew kit - you need to make sure the spring and retainer pressed back into the hole correctly AFTER you put the correct ball into the hole.
You should compare the original and the replacement ball to make sure they are the same size/type/wieght or the pump shot will be effected...
The ball seat should also be checked during rebuild to make sure it is not corroded or any dirt/gunk remains as it can cause the ball to stick.
You normally don't need to remove the screws from Cross-shafts when doing routine rebuilds - but, since you did - just put "Red" Loc-Tite on the screws and you will be fine
You can even put a drop on the screw side of each and let it go - they will probably never fall out and if they did they wouldn't do much...
I've found them missing on more than a few units with no problem
Hope some of that helps...
1968 Convertible
Some trucks
Vintage 68 is offline
post #7 of 16 (permalink) Old Mar 17th, 09, 12:39 PM Thread Starter
Jeff
Thanks for the info John! So, here's the thing about the ball. I never took one out of the pump. I suppose it is possible that it fell out without me noticing, but I was trying to be very careful about that. Also, there was a note in the rebuild kit instructions that the ball did not go on such and such model (I don't have the instructions with me right now; I don't remember the exact wording). All I ever took out of the accelerator pump was the spring (which was cleaned with everything else and replaced appropriately as far as I can tell, and the plunger. A new plunger came with the kit, so I transferred the cleaned spring and retainer clip to the new plunger after I verified the plungers were basically identical. There was no ball in the bottom. I still have the aluminum ball in the kit. Should I drop it in?
Bear with me... this was my first carb rebuild.
jkaufman is offline
post #8 of 16 (permalink) Old Mar 17th, 09, 12:48 PM
Vintage 68's Avatar
Red face Re: Carburetor Rebuild
I've done a "few" and never ran across one without the discarge check ball
There is only one ball in any 2G/GC/GV I've ever seen - the one under the spring.
Doesn't make any sense for there to be a spring without something for it to hold down...
So I would remove spring and install ball.
Assembly should be:
1. ball
2. spring
3. retainer ('T' shaped thingy)
1968 Convertible
Some trucks
post #9 of 16 (permalink) Old Mar 17th, 09, 01:00 PM Thread Starter
Jeff
Assembly should be:
1. ball
2. spring
Ah. I think we are talking about two different balls here... I know about the steel ball under the small spring and T retainer. My kit came with a replacement ball, spring, and retainer and I used the replacements. However, there was a second ball in the kit. It was a little bit smaller and was aluminum (less shiny and checked with a magnet). Apparently on certain Rochester models (maybe not mine?) it goes down in the area beneath the plunger. That spring is quite a bit larger though and wouldn't hold the smaller aluminum ball at all. Maybe a mesh screen would hold the ball down on models that required the ball in that area?
So, if I am not supposed to use the aluminum ball on a 2bbl Rochester (and I didn't), what's next?
jkaufman is offline
post #10 of 16 (permalink) Old Mar 17th, 09, 01:14 PM
Vintage 68's Avatar
Originally Posted by jkaufman View Post
... would hold the ball down on models that required the ball in that area?
... what's next?
Okay, some HD carbs did have a bottom-fill slot with the check ball in the base retained by a strap...
Next:
1. recheck float level to be sure it is high enough
2. readjust the pump lever so there is no free-play and it actuates the pump as soon as the throttle is opened.
1968 Convertible
Some trucks
post #11 of 16 (permalink) Old Mar 17th, 09, 02:00 PM
I remember that little ball, spring, T thing. It's the same in a Q-jet, right? Isn't the purpose to keep the pump chamber full of fuel? Seems to me if the surface that the ball seats in is dirty or otherwise corroded, fuel would/could leak back into the float bowl, screwing up the accel pump shot. It's been awhile.
BPOS is offline
post #12 of 16 (permalink) Old Mar 17th, 09, 04:37 PM Thread Starter
Jeff
Next:
Okay. I will check those things when I get home from work. I know how to check the float level and drop, but what is the best way to check that the pump lever is actuating the pump as soon as the throttle is opened? Just move the pump lever by hand? Or just watch/feel it while I open the throttle by hand? Or?
Thanks!
jkaufman is offline
post #13 of 16 (permalink) Old Mar 17th, 09, 05:04 PM
Hold the choke butterfly open with one hand and operate the throttle linkage with the other while looking down the throat of the carb. The SLIGHTEST movement of the throttle should produce a squirt of fuel.
BPOS is offline
post #14 of 16 (permalink) Old Mar 17th, 09, 05:15 PM Thread Starter
Jeff
Okay. Easy enough. So, if no fuel is squirted out, do I modify the pump rod so that it actuates earlier with the throttle?
jkaufman is offline
post #15 of 16 (permalink) Old Mar 17th, 09, 06:15 PM
Brandon
Correct. You shouldn't have any play between the pump lever and the actuating arm from the accelerator linkage. It should be instantaneous. Just make sure that the pump arm isn't depressing the pump. It's only to be just to it otherwise your defeating the purpose of the pump by limiting the amount that of gas that squirts in as the carb cycles between idol and off idol circuits.
Nantooch is offline
