stubborn BBC motor mounts - Team Camaro Tech
post #1 of 14 (permalink) Old Mar 15th, 09, 04:50 PM Thread Starter
Tom P's Avatar
I am trying to swap in a set of ES Poly motor mounts on my 396. They are the stock 1969 tall and narrow rubber mounts. Problem is I cannot get the old one out.
I have the disconnected the Z-bar for the clutch, dropped the exhaust, removed the headers, fan, dist. cap, etc
When I jack (with plywood) under the pan, the whole chassis lifts. The motor mounts are not separating from the frame mounts.
I am stumped, any ideas?
I suppose I can remove the frame mounts, but trying to avoid that.
thanks!
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #2 of 14 (permalink) Old Mar 15th, 09, 05:05 PM
Skip
Skeeter55's Avatar
Re: stubborn BBC motor mounts
Yeah try disconnecting the trany mount and see if that helps (jack it up toward the rear of the block). Then jack it back up and if it doesn't come apart stick a long screw driver to help pry it apart.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #3 of 14 (permalink) Old Mar 15th, 09, 05:34 PM
Fred
Tom, don't yell at me. I didn't see where you pulled the bolts between the engine and frame halves.
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 14 (permalink) Old Mar 15th, 09, 06:07 PM Thread Starter
Tom P's Avatar
no yelling, at least not anymore
Yes I did pull the bolts.
Looks like I need to invest in a prybar - LARGE screw driver to pry those mounting tabs away from the frame mount. it is a pretty tight fit.
Tom P is offline
post #5 of 14 (permalink) Old Mar 15th, 09, 06:12 PM
Skip
Skeeter55's Avatar
It will be tight going in too.... So get it close and have some patience look in the hole with a flashlight and adjust the motor from front to back and side to side. It will also help to us a punch or a Philip's screw driver to get the hole center, i did this last week and still had to smack the bolt a little and used a socket wrench and threaded it threw.
post #6 of 14 (permalink) Old Mar 15th, 09, 06:33 PM Thread Starter
Tom P's Avatar
Thanks Skip,
Did you install the Poly mounts?
Tom P is offline
post #7 of 14 (permalink) Old Mar 15th, 09, 06:37 PM
Skip
Skeeter55's Avatar
Thanks Skip,
Yes and wow they are a tight fit. I was lucky enough because i had the frame mounts off the frame and i went a head to dry fit them with a little help of a rubber mallet to smack the motor mounts over the frame mounts. Then installed the frame mounts and motor after, still a tight fit but the motor stays put when its running.
post #8 of 14 (permalink) Old Mar 22nd, 09, 05:01 PM Thread Starter
Tom P's Avatar
ended up taking the frame mounts off, but it also gave me a chance to clean everything up. Removing the frame mounts was not really that bad, the trick was getting the bolts started inside the crossmember during re-assembly.
The Energy Suspension mounts fit perfectly
Tom P is offline
post #9 of 14 (permalink) Old Mar 22nd, 09, 05:27 PM
Skip
Skeeter55's Avatar
Nice job Tom ...... What do you have planed for exhaust manifolds or headers.
post #10 of 14 (permalink) Old Mar 22nd, 09, 06:06 PM Thread Starter
Tom P's Avatar
I've got a set of the Patriot shorty headers. They are easy to remove and it gave me plenty of clearance for getting at the mounts.
This all started as a conversion from manual steering to AGR PS box. Since I need a PS pump and new brackets decided to convert everything to a March Serpentine setup.
This was just a good excuse to change over to the poly mounts - clearance between the headers and new PS box is going to be tight.
Tom P is offline
post #11 of 14 (permalink) Old Mar 22nd, 09, 06:11 PM
Skip
Skeeter55's Avatar
Awesome sounds like you did your homework . Take some pics when your all done and post them i and others would love to see the progress in the shorty's .
post #12 of 14 (permalink) Old Mar 22nd, 09, 06:11 PM
prostreet69camaro's Avatar
I just put a set of the shorty headers on the 69. I had to jack up the drivers side to install the header because the steering box was in the way. The passenger side fit with no problems.
prostreet69camaro is offline
post #13 of 14 (permalink) Old Mar 22nd, 09, 06:14 PM
Skip
Skeeter55's Avatar
Holy cow that thing is beautiful and im very jellious... Mike boy is sure does look sweet.
post #14 of 14 (permalink) Old Mar 22nd, 09, 06:25 PM
Thats very "perty'" very nice I like fulie cars,
john68 is offline
