engine gremlins. - Team Camaro Tech
post #1 of 23 (permalink) Old Apr 12th, 09, 12:53 PM Thread Starter
Ashlee and Andy
engine gremlins.
I decided to do a quick tear-down and regasket on the 350 in my 68 camaro, I had the valves in the heads freshened up last year, checked the cam (one low lobe, nothing to bad) and aligned the cam-crank.
I have tried to start the car for a few days now, I'm getting around 50lbs of compression on all cylinders, which is very low, and can't seem to get any extra compression out of it. I've adjusted valves several times, tighter, looser, zero lash and "clacky" and haven't had any improvement, also rechecked and re-aligned the cam and crank.
Any ideas or suggestions? I don't have a leak-down tester handy or a spark checker either.
ap68 is offline
post #2 of 23 (permalink) Old Apr 12th, 09, 03:11 PM
Steps
Re: engine gremlins.
Even at 50 lb the engine will fire if has spark, compression and fuel.
Steptoe is offline
post #3 of 23 (permalink) Old Apr 12th, 09, 03:16 PM
Brandon
threre is that 180* out thing to consider.
Brandon J. licence 1NASTY67
Nantooch is online now
post #4 of 23 (permalink) Old Apr 12th, 09, 04:40 PM Thread Starter
Ashlee and Andy
timing is set so the dot on the cam and crank are straight up, rotor pointing at number one.
50 psi, would be like runnign a 5:1 CR. is there an actual likely hood of the car getting a better compression or did I end up doing something wrong?
ap68 is offline
post #5 of 23 (permalink) Old Apr 12th, 09, 07:01 PM
jared
Should'nt the two timming marks be pointing at each other<cam pointing down and crank shaft pointing up> and could have the crank gear on the wrong degree mark!
jcfcamaro is offline
post #6 of 23 (permalink) Old Apr 12th, 09, 08:02 PM Thread Starter
Ashlee and Andy
pointing at each other is to fire #6, both pointing up supposedly fires #1 TDC... I checked the cam 3 times today to no avail. still 50 lbs
Edit: motor is a 30 over 74 350, wiseco flat top pistons with valve reliefs, stock iron heads (1.90 intake) edelbrock performer RPM and holley 650 cfm, ran great last year, and I'm really thinking that 50 PSI is way to low for this motor.
ap68 is offline
post #7 of 23 (permalink) Old Apr 12th, 09, 09:31 PM
butch
you are 180 out you need the cam and crank dots pointing at each other cam down and crank up you were mis informed about your setting
ugot86d is offline
post #8 of 23 (permalink) Old Apr 13th, 09, 07:57 AM
A couple things you can do as others have suggested.
With camshaft arrow/mark pointing down and directly over the imaginary centerline between the cam & crank, place the crank socket pointing directly in the middle of the chain slack. If they don't align/poin to each other, the cam or crank might be off a tooth or so. I have worked on a Buick 350 being three teeth off still collect 90 PSI of compression.
Advance/retard the camshaft a tooth at a time and take a compression reading for each tooth. The higher the compression, the right direction.
Fifty PSI in all cylinders? Correct head gaskets used? Torqued correctly?
post #9 of 23 (permalink) Old Apr 13th, 09, 08:17 AM Thread Starter
Ashlee and Andy
Yup... Thats why it was hard to understand what could be wrong for them all to have such low compression... it wouldn't be so odd if one or a couple had low compression, but all of them?
ap68 is offline
post #10 of 23 (permalink) Old Apr 15th, 09, 12:56 PM
Tyler
I agre with ugot86d you were misinformed on you cam intall.. get #1 to top dead center and line up the dots.
wyant777 is offline
post #11 of 23 (permalink) Old Apr 15th, 09, 01:25 PM
Shawn
#1 firing TDC on my engine was when both dots were pointing up
victimizati0n is offline
post #12 of 23 (permalink) Old Apr 15th, 09, 04:39 PM
Assuming the cam was installed correctly - it sounds like it was. Cam dot down, crank dot up. (dot to dot) If you removed the crank gear during the freshen up, some of those buggers have 3 keyways on them and can be confusing. If you didn't remove the crank gear, disregard.
You are correct - when the cam is installed "dot to dot" it is ready to fire #6, not #1. Crank dot up and cam dot up is ready to fire #1 - so you got that right.
You are getting the lifters on the base circle as you adjust the valves, right? And you trust your compression gauge?
BPOS is offline
post #13 of 23 (permalink) Old Apr 15th, 09, 06:16 PM
Shawn
thanks for the info, when i tore my timing cover off, i was confused when i saw that, because i thought dot to dot should be firing on #1, until i did a bit of research, and this thread pretty much confused me
post #14 of 23 (permalink) Old Apr 16th, 09, 05:40 AM
You can line it up either way. I always go dot to dot so that there is less chance for error. If it is 180o out, just drop the distributor 180o the other way. If the compression is low try backing the rocker arms off some and checking. It could be a valve tightened down a little too much.
lluciano77 is offline
post #15 of 23 (permalink) Old Apr 16th, 09, 07:48 AM
There is some very confusing information here! When I install them, first verify that #1 piston is at top dead center. Then I line the dots so that the crank dot is straight up and the cam dot is straight down. Move nothing now until you install your timing cover and pointer. Verify that your pointer is actually pointing at 0* (some will point at 4* BTDC which is fine). You just might have the balancer that has the timing mark up near the 12 o'clock position at TDC. If so, mark your damper with a paint stripe at zero. Now, after marking 0, rotate your crank 180* and install your distributer to fire at #1 piston. You should now be good to go. From youir description, I suspect you have the 8" balancer with the timing mark at near 12 o'clock.
deerhunter is offline
