68 intake with flat hood - Team Camaro Tech
post #1 of 9 (permalink) Old Jul 16th, 09, 11:47 PM Thread Starter
I'm sure this has been asked, but I can't find exact info using search.
I have a 68 I'm trying to get back on the road and have some fun with.
Got a 327 that had a super victor on it, and I took it off thinking it wouldn't fit my flat hood (probably true, it's HUGE, the engine ran 9000 rpm in my race jeep)
I have a C3BX manifold that I own, and a Performer RPM Air Gap my friend said I could repay him later for.
I'm using a 750 holley HP on it.
Does the RPM Air Gap fit the flat hood with a Holley?
Does the C3BX fit the flat hood with any more clearance than the Air Gap?
Which would give me more drag-strip performance? I know this engine is going to be starving for air either way (11:1 w/.555 lift solid 106º cam) but if the C3BX will fit better and perform good (the runners are bigger cross section) I might be better off running the older one....
Any info would help before I seal it up with an intake that doesn't fit.
jerkbucket is offline
post #2 of 9 (permalink) Old Jul 17th, 09, 03:38 AM
Re: 68 intake with flat hood
I was running a flat hood with a 406ci small block topped with a Vic Jr,a Holley 750dp,and a drop base air cleaner with about 1/4 of an inch to spare.
68 Camaro~LSx ~all motor
post #3 of 9 (permalink) Old Jul 17th, 09, 07:38 AM Thread Starter
OK, how does the height of the AirGap compare to a Vic Jr?
post #4 of 9 (permalink) Old Jul 17th, 09, 01:54 PM
AJ
I have a friend who runs a vctor jr. with a holley under a stock '68 flat hood. There are a few different versions of the Victor jr, all having different plenum heights, I am not sure his is the shorter one to fit for that purpose.
You say you have a victor jr. and rpm air gap on hand? Measure them and find out, using a ruler, eyeball or set them both on the motor and test fit it.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 9 (permalink) Old Jul 17th, 09, 04:46 PM
Even today, the old C3BX is a good intake, imho. Use it!
It may NOT have the quality of air flow that an RPM will have,, BUT I bet it will have more overall volume of flow!
And this is why the old Weiand 8016 Stealth is still a good intake on the bigger SB's.
pdq67
post #6 of 9 (permalink) Old Jul 17th, 09, 06:00 PM Thread Starter
pdq67
I will agree with that, the C3BX has some big runners, lots of volume! Actually when I took the super victor off, the ports from the C3BX looked like they have a bigger opening than the Victor, so for the street and fitting under the hood, I bet it works fairly well in comparison, for the application. If someone disagrees, I might still go the Air Gap, I have a couple days before I bolt something on. But I'm sure the C3BX would have the best clearance.
post #7 of 9 (permalink) Old Jul 17th, 09, 07:28 PM
Go for it and use the extra money that's left over to buy a 12 pack a BEER!!
pdq67
post #8 of 9 (permalink) Old Jul 18th, 09, 01:16 AM Thread Starter
pdq67
A fair plan at least, gotta love the beers!
post #9 of 9 (permalink) Old Jul 18th, 09, 10:22 AM
Lane
I vote for the air gap. It really runs better on hot days. And yes it will easily fit with a holley under a stock flat hood. You can click my link to see my engine pics.
Lane
rlyfst1 is offline
