help with edlebrock Performer 750 - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 21st, 09, 03:00 PM Thread Starter
dan
danimaldds's Avatar
I have a stumble on clutch out. Would moving the accelerator pump linkage help solve this problem. As a start at least.
Dan
1969 SS 383 Stroker , TKO 600, 3:73
1964 vette conv. 327/ 300 freshly ,completely repainted. I mean everything!
danimaldds is offline
post #2 of 4 (permalink) Old Jul 21st, 09, 03:08 PM
Neil
Re: help with edlebrock Performer 750
I would give it a smaller shot and see what happens. It may also be the stepup springs or need to be re-jeted
fng68ls1 is offline
post #3 of 4 (permalink) Old Jul 21st, 09, 04:15 PM Thread Starter
dan
danimaldds's Avatar
This is the carb that was dyno'd with the motor. I can see that it may be missed since the load on the motor is nominal on an eng. dyno. you think Less huh? I thought more. Easy to do I guess.
Dan
post #4 of 4 (permalink) Old Jul 21st, 09, 04:30 PM
Neil
Was the carb tuned on the dyno? I have never had one done so I don't know. It may just be the step up springs. If there isnt enough vacuum to pull them down at idle, it may be causing them to run in the up position.
fng68ls1 is offline
