1969 1970 Z/28 aluminum manifold ---carbs - Team Camaro Tech
post #1 of 11 (permalink) Old Jul 25th, 09, 11:51 AM Thread Starter
I have a line on an aluminium high rise manifold from a 1969/ 70 Z. I was wondering if I can use my Quadrajet carb on it?
I have owned 3 69 Z/28s: Garnet Red 30,000 mi unrestored.
Glacier Blue, documented Canadian Z
Rallye Green purchased new in 1969
1968 Camaro Coupe L30 275 horse. ]
Stewie is offline
post #2 of 11 (permalink) Old Jul 25th, 09, 01:39 PM
Smile Re: 1969 1970 Z/28 aluminum manifold ---carbs
No, only a Holley unless you want to install a Q-Jet to Holley adapter.
I wouldn't tho if it was mine.
pdq67
post #3 of 11 (permalink) Old Jul 25th, 09, 02:15 PM Thread Starter
Thanks PD. Why not use the adaptor?
Stewie is offline
post #4 of 11 (permalink) Old Jul 25th, 09, 05:06 PM
It's not optimal flow, it raise's the carb about 5/8" to 3/4" higher and it doesn't look pretty.
Other than these three points, it's fine to use by me.
pdq67
post #5 of 11 (permalink) Old Jul 25th, 09, 06:22 PM Thread Starter
Good enough reasons for me! Thanks again. I guess I will go the easy route and get a manifold I can use with my carb. I still might buy it if I can get it for a low ball offer.
Stewie is offline
post #6 of 11 (permalink) Old Jul 25th, 09, 11:26 PM
I wouldn't worry about it b/c a good old Holley 300-36 is right in there and you won't be paying any sort of GM Z-28 PN increase in price, imho.
pdq67
post #7 of 11 (permalink) Old Jul 26th, 09, 08:40 AM Thread Starter
PD as usual I am going to call on your expertise on the 300-36. What is the complete part number I am looking for. I have been lurking on ebay and there are several. One is a current model 300-36c with an everbright finish. I guess that is the polished and I don't want that one. Another is 701-r-36 300-36. I am asuming that is the one I should be looking for? The only thing that throws me is there is only one set of bolt holes. Thanks in advance for any help.
Stewie is offline
post #8 of 11 (permalink) Old Jul 26th, 09, 10:05 AM
Heck, a 300-36 is just that as far as I recall.
Unless Holley made one w/ the different angled four centered bolts?
Got a new one in it's box in my bedroom closet so may have to pull it out and look?
pdq67
post #9 of 11 (permalink) Old Jul 26th, 09, 01:28 PM Thread Starter
Thanks PD. I am a newbie to carb switching etc. All my previous cars were Zs and that is pretty much straight forward holley 4053. I have had several DZ carbs.
I found out that my Quad is from a 72 Camaro 350/175 application, Would that be a dog on a warmed up 327?
Stewie is offline
post #10 of 11 (permalink) Old Jul 26th, 09, 02:25 PM
Probably about dead-nuts on once the top rear butterfly's are set to tip in where you want them to.
pdq67
post #11 of 11 (permalink) Old May 29th, 10, 06:37 AM
Brian, does the manifold have the winters "snow flake" logo on it? I am looking at the same thing for my '69. earlier this morning, I came across a good site regarding the Winter's high rise manifold and proper Holly carb for the set up; and listed the part numbers which should be stamped. I'll find that site again and post later today when I'm on a different computer. What kind of cost are you looking at if you don't mind??
okiemark is offline
