396 BB help - Team Camaro Tech
post #1 of 10 (permalink) Old Jul 31st, 09, 06:50 PM Thread Starter
396 BB help
I have a 396 BB with less than 150 miles, runs great until the water temp hits 195. Then she runs rough and will stall at traffic lights. I have a speed demon 650 carb, holley 12-454-11 fuel pump, could this be the timeing or carb settings? I will be glad to add more information if I can answer tem. thanks for your help.
G8trhtr is offline
post #2 of 10 (permalink) Old Jul 31st, 09, 07:05 PM
Smile Re: 396 BB help
What type of choke does it have ?
TJS69 is offline
post #3 of 10 (permalink) Old Jul 31st, 09, 07:11 PM Thread Starter
Re: 396 BB help
the demon carb has an elec choke, but it apperas to be wire tid open. just bought the car.
G8trhtr is offline
post #4 of 10 (permalink) Old Jul 31st, 09, 11:38 PM
JAY
Re: 396 BB help
lots of questions,
does it restart ok?
if it hard restart then have someone help you
check for spark/fuel....have you done compression test
to see if there is water getting into cylinders? Have you checked fuel lines might be to close to exhaust causing
vaper lock? Here in arizona we are sometimes challenged
with heat and poor running engines when its 107 outside those poor cars have hard times jay
JAYARTER is offline
post #5 of 10 (permalink) Old Aug 1st, 09, 07:34 AM
Dan Ensign
Re: 396 BB help
Is the coil getting hot and cutting out, float levels too low or sticking needles in carb, or floats too high and flooding, drawing fuel thru the boosters at idle, metering blocks dirty in carb, is the gas cap vented? Just a few quick ideas.
Dan E.
69 SS396 4spd. 4.11 posi. x66 coupe
Dan E. is offline
post #6 of 10 (permalink) Old Aug 1st, 09, 02:39 PM Thread Starter
Re: 396 BB help
I will work on these today. What does a "vented " gas cap prevent?
G8trhtr is offline
post #7 of 10 (permalink) Old Aug 1st, 09, 03:05 PM
Most engines require a "vented" gas cap, that allows air into the gas tank. If it is not vented a vacuum is created and fuel will not flow. It is kind of like a beer can... if you punch a hole in the bottom of it, you can drink it a lot faster!
TJS69 is offline
post #8 of 10 (permalink) Old Aug 1st, 09, 07:01 PM
Ron
Re: 396 BB help
Another Consideration - It takes a BBC 20 minutes before reaching operating TEMP and the reason why I start moving and hope it warms up enough to trip the thermostat before I get to where I'm going; other words, you will spend more fuel then it takes to get there just waiting for the "BEAST" to wake up.
This was my 70 1/2 Z28
Z15CAM is offline
post #9 of 10 (permalink) Old Aug 1st, 09, 07:16 PM
JohnZ's Avatar
Re: 396 BB help
Check pump-to-carb fuel line routing - could be fuel percolation.
JohnZ
CRG
JohnZ is offline
post #10 of 10 (permalink) Old Aug 2nd, 09, 11:25 AM Thread Starter
Re: 396 BB help
I think I will try and place some type of heat shield around or over the fuel line on the frame rail. the headers are about half an inch from the fuel line.
G8trhtr is offline
