454 ready to start/break-in **Pics** - Team Camaro Tech
post #1 of 10 (permalink) Old Aug 3rd, 09, 06:11 PM Thread Starter
Louie
rad454's Avatar
I'm getting ready to start the 454 later this week. The engine has a roller cam, 9.5:1 CR and bored .040 over.
Is there any difference in breaking in a rebuilt engine as opposed to a new crate motor. Is there anything I should be specifically looking for on start up? I have an oil pressure, engine temp, vacuum and fuel pressure guage ready.
69 SS/RS Fathom Green 454 4 speed
Bumper sticker- My other auto is a .45
rad454 is offline
post #2 of 10 (permalink) Old Aug 3rd, 09, 06:18 PM
Matt
8ballracing's Avatar
Re: 454 ready to start/break-in **Pics**
Fire extingusher.......never know
Looks like you are ready to go.....good luck!
8 Ball Racing
Member #120
1969 X77 9 E 69 302 M21 Wallace Chevrolet
1969 RSSS rag top 7 E 69 350 turbo 350
1969 Triple Blue 10 D 68
1968 Chevelle 03 A 68
8ballracing is offline
post #3 of 10 (permalink) Old Aug 3rd, 09, 07:03 PM
george
return spring on the clutch fork and the trans in nuetral or you will be wearing that yoke.Gear lube in the manual trans?Wheres the timing light?
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #4 of 10 (permalink) Old Aug 3rd, 09, 07:08 PM
Skip
Skeeter55's Avatar
Yeah what cam are you running and put a large fan up front to help cool down also the headers are going to glow if its not running a little on the rich side.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #5 of 10 (permalink) Old Aug 3rd, 09, 07:19 PM
Dan Ensign
Earplugs! ZDDP additive in the oil. Oh and a video camera!
Dan E.
69 SS396 4spd. 4.11 posi. x66 coupe
Dan E. is offline
post #6 of 10 (permalink) Old Aug 3rd, 09, 09:40 PM Thread Starter
Louie
rad454's Avatar
I'm definitely going to video this start up. Got the fire extinguisher. Fan in front of the rad is a good idea, I will do that. Got oil in the tranny but I forgot about putting the clutch return spring on. Thats why I asked and usual, you guys deliver. Thanks. Post the vid as soon as I can.
rad454 is offline
post #7 of 10 (permalink) Old Aug 4th, 09, 03:04 AM
Roller cam with no load on the engine.. Headers won't get at all hot.
PS. How do you post just the urls of Youtube links instead of the way it's shown here??
BlackoutSteve is offline
post #8 of 10 (permalink) Old Aug 4th, 09, 04:48 AM
BILL
SPARKY69's Avatar
Nice!!!
SPARKY69 is offline
post #9 of 10 (permalink) Old Aug 4th, 09, 08:35 PM
Just looking at your pics again.. I know that the radiator support may sway a little and your fan will have some pulling power. Perhaps you should try to secure the support so the fan doesn't pull the support inward and mince your radiator's core once the engine is running..
..and to answer your Q, you have a roller cam, so just crank, fire, and run it.
If it's a solid, once it gets to about 180F, check your lash setting.
post #10 of 10 (permalink) Old Aug 4th, 09, 09:28 PM Thread Starter
Louie
rad454's Avatar
Steve, good observation on the radiator support. I tightened the support bolts but it does move a little because of the rubber bushings. I will brace the support with some channel iron. That will sturdy it up substantially.
In additionto the pics above, I added a 1/2 inch phenolic spacer. It's flat on one side and has cast in spaces on the other. Can anyone tell me which side faces the underside of the carb?
rad454 is offline
