69 Camaro oil pan - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 8th, 09, 12:33 PM Thread Starter
JIM
69 Camaro oil pan
Is it possible to remove the oil pan from a 69 Camaro without taking out the engine?
JIM SHOENFELT is offline
post #2 of 5 (permalink) Old Aug 8th, 09, 01:14 PM
JcGc's Avatar
Re: 69 Camaro oil pan
Is it a stock pan? if so Yes you can. You will have to lift the motor up alittle so you can get the pan to clear the oil pump.
It's not that hard to do. I have done this myself before I put on a bigger pan.
1969 Camaro
JcGc is offline
post #3 of 5 (permalink) Old Aug 8th, 09, 01:44 PM Thread Starter
JIM
Thank you so much for the info. I am going to remove the starter, alternator and fan. I am using holes on the heads and figure I can lift it about 2-3 inches. Do you think that will work?
post #4 of 5 (permalink) Old Aug 8th, 09, 07:32 PM
Alan
Watch out for the distributor cap when you raise the engine.
alan
alanrw is offline
post #5 of 5 (permalink) Old Aug 8th, 09, 07:51 PM Thread Starter
JIM
Thanks for the tip. I forgot about that.
