327 11:1 pistons with aluminum heads - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 22nd, 09, 06:46 PM Thread Starter
Has anyone used the L2166NF pistons with a newer style combustion chamber on most aluminum heads now on the market. Thinking about changing my 461's but didnt know if i would have clearence issues.
66chevyiiss327 is offline
post #2 of 4 (permalink) Old Sep 23rd, 09, 02:32 AM
Ron
Re: 327 11:1 pistons with aluminum heads
That's the piston I use in my 68 Forged Medium Journal 327 4 bolt 010 Block but I run a set of Grumpy Spec'd 281 Turbo Castings. To me if you can bolt after market Alu-Cylinder Heads on a 350cu running domes, I can see no issues bolting them onto a 327 as they are basically a LT1 engine.
This was my 70 1/2 Z28
Z15CAM is offline
post #3 of 4 (permalink) Old Sep 23rd, 09, 07:28 AM
mbrekke's Avatar
You shouldn't have any problems with the modern fast burn type chambers. I have those pistons with these heads on my 327 with no issues.
http://www.dartheads.com/products/cy...s-s-heads.html
They won't work with Vortec style chambers though because the point of the heart shape sticks out too far into the chamber.
http://www.chevymania.com/tech/vortec.htm
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
mbrekke is offline
post #4 of 4 (permalink) Old Sep 23rd, 09, 08:20 AM
Ron
Good info Mark: I wasn't thinking Vortec could be after market.
Z15CAM is offline
