396 heads - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 4th, 09, 01:38 PM Thread Starter
Chuck
396 heads
Anyone see any problems running these heads with a 396?
http://www.summitracing.com/parts/AFR-2100/
Looking for a good head with stock intake and exhaust locations. Thanks
chuck0379 is offline
post #2 of 5 (permalink) Old Oct 4th, 09, 02:13 PM
Re: 396 heads
If the car is to be driven on the street 80% of the time i would look in to oval ports over square ports. Better low end TQ which is king on the streets.
Something like these:
Street High-Performance Heads
PERFORMER & PERFORMER RPM 454-O
These oval port heads will support over 540 hp with 9.5:1 compression when used as part of the Total Power Package
Unique oval intake port shape produces flow similar to rectangular ports, but the smaller port size provides excellent seat-of-the-pants performance and crisp throttle response
Semi-open chamber design maximizes efficiency with streetable compression ratios
Smaller-than-stock 11/32" valve stems promote excellent flow and lighter valve weight
PERFORMER 454-O
Chamber Size Intake Port Size Valve Sizes (in/ex) Bare (single) Complete (single)
110cc 290cc 2.19"/1.88" #60469 #60479
Rogers Performance is offline
post #3 of 5 (permalink) Old Oct 5th, 09, 04:12 AM Thread Starter
Chuck
Re: 396 heads
Thanks for the info. This will be my first BB build so any help is appreciated.
Here is a edelbrock kit from summit and includes almost everything. I'm not looking to break any records, but just a good street motor.
http://www.summitracing.com/parts/EDL-2095/?image=large
Also is there any way to tell if the block has been bored in the past?
post #4 of 5 (permalink) Old Oct 5th, 09, 06:17 AM
Re: 396 heads
You can,t go wrong with a kit like that.
post #5 of 5 (permalink) Old Oct 5th, 09, 06:56 AM Thread Starter
Chuck
Re: 396 heads
Thanks Mike.
