building 327 - Team Camaro Tech
post #1 of 15 (permalink) Old Oct 8th, 09, 01:17 PM Thread Starter
jim
building 327
what u engine guys think about this cam has 420/443 lift 110degree lobe sep.or i can get it with112 lobe sep.going to have flat top pistons quadajet intake q-jet replament holley carb 291 heads headers 350 turbo trans 3.08 gears intake is q-jet 803 last 3 numbers
cars68 is offline
post #2 of 15 (permalink) Old Oct 8th, 09, 02:00 PM
Re: building 327
That sounds like the same spec as the Edelbrock performer cam. My 327 is running the CS-1014 same spec with 112 lobe sep. It's really just one step above stock. Better with good heads and headers but not a bad little cam for a street car. Pulls 18 inches of vaccuum or more. Search on performer cam or CS-1014 for more info.
Melrose RS is offline
post #3 of 15 (permalink) Old Oct 8th, 09, 02:20 PM Thread Starter
jim
Re: building 327
its same cam
cars68 is offline
post #4 of 15 (permalink) Old Oct 8th, 09, 02:21 PM
Smile Re: building 327
What is the duration on that cam ? With only lift numbers, it doesn't mean anything.
TJS69 is offline
post #5 of 15 (permalink) Old Oct 8th, 09, 02:36 PM
Re: building 327
Duration is 204/214 at .050"
post #6 of 15 (permalink) Old Oct 8th, 09, 03:05 PM
mbrekke's Avatar
Re: building 327
Which 291 heads are they? The later version had smaller ports and 76cc chambers. 76cc chambers and flat tops in a 327 ain't good... Do they have accessory holes?
http://www.chevytech.info/3c3917291.html
http://www.chevytech.info/3c3912291.html
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
mbrekke is offline
post #7 of 15 (permalink) Old Oct 8th, 09, 04:36 PM Thread Starter
jim
Re: building 327
no acc.holes casting date E-24-7
cars68 is offline
post #8 of 15 (permalink) Old Oct 8th, 09, 08:00 PM
I think that date code says May 24, 1967.
I would look at the Voodoo 60101 cam. http://www.summitracing.com/search/?...%2060101&dds=1
Hydraulic Flat Tappet, Advertised Duration 256/262, Lift .454/.468, Chevy, Small Block
I would look at the Voodoo 60102 cam. http://www.summitracing.com/search/?...%2060102&dds=1
Hydraulic Flat Tappet, Advertised Duration 262/268, Lift .468/.489, Chevy, Small Block
TJS69 is offline
post #9 of 15 (permalink) Old Oct 9th, 09, 08:39 AM
mbrekke's Avatar
Re: building 327
I would go with a little more cam than your original choice, as Tom suggested, as long as you have decent valve springs. The good old Comp 268H (not the XE) would be another choice. If you have stock springs that are old and worn out you may run into coil bind with anything much over .450 lift. Some cheap Z-28 type springs would be an inexpensive upgrade.
Do you have a stock torque converter? Power brakes? These are also things to consider. Too big of a cam and you'll run into problems idling in gear with a stock converter, and brakes that don't get enough vacuum to work correctly in traffic.
Then again maybe you have considered all these things and that's how you arrived at your first choice...
mbrekke is offline
post #10 of 15 (permalink) Old Oct 9th, 09, 10:25 AM Thread Starter
jim
Re: building 327
dont want to big of cam have power brakes something little more than stock
cars68 is offline
post #11 of 15 (permalink) Old Oct 9th, 09, 10:49 AM
They have a smaller voodoo also, the 60100 cam is quite similar to your 1st cam you were looking at. I would not worry about low vacuum on any of theses cams. They are not very big. I would keep it smaller using those heads though. Those heads are good to get your compression up, but they are not going to breathe very well. (small ports) If you put too large of a cam in it, it will feel like you are hitting a wall and it will not RPM. If you stay smaller on the cam, it should RPM to the moon ! I would go 262 max.
TJS69 is offline
post #12 of 15 (permalink) Old Oct 9th, 09, 11:18 AM
AJ
Re: building 327
The good old 268 he referred to will get you more than enough to run power brakes, probably 13"-18" of vac.
Some of us only have 6"-8" of vacuum and still run power brakes.
268 is a great cam for a stock-ish 327... If the heads are the huge 75cc chamber smog heads with 1.72" valves, I wouldn't do anything to the motor until I could replace the heads with something at least decent, like a double hump, vortec, anything but the 75cc heads really.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #13 of 15 (permalink) Old Oct 9th, 09, 01:05 PM Thread Starter
jim
Re: building 327
the heads r double hump 291s
cars68 is offline
post #14 of 15 (permalink) Old Oct 9th, 09, 02:14 PM
mbrekke's Avatar
Re: building 327
If all you're looking for is a little more than stock and don't want to have to mess with changing valve springs, then that cam should work well for you. If you had a 4-speed and a little more rearend gear I would definitely step up to a little bigger cam though.
mbrekke is offline
post #15 of 15 (permalink) Old Oct 9th, 09, 04:37 PM Thread Starter
jim
Re: building 327
thanks for all the info guys i think the cam i refered to will be fine
cars68 is offline
