383 stroker motor,,,,, oil pan - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 12th, 09, 07:59 PM Thread Starter
Lane
I am thinking about making 350 in 68 Camaro into 383 Stroker.
Will stock oil pan work?
No power steering......just stock stabilizer and factory 68 front suspention.
If stock won't work...what are you using for this application?
Thanks....Lane
Lane 68 is offline
post #2 of 5 (permalink) Old Oct 12th, 09, 08:03 PM
Rick
Re: 383 stroker motor,,,,, oil pan
I used my original pan from my 327.
Rick
Rick
68 project...reassembly starting: (383, AFR 195, Air Gap, Comp Cam XR276HR, 1.6 CC Gold rollers, Holley 750, 4/09) (TKO 600 conversion from T350 4/09) (floor pan restored 6/09). (12 bolt 3.73, Wilwood disc, Hotchkis TVS 7/09), Dougs 368 with Big Dog mufflers (9/09), 383 fired up 9/30/09, Candy Apple Red 2012 with white RallyBee stripe
dukemd66 is offline
post #3 of 5 (permalink) Old Oct 12th, 09, 09:07 PM
Keith
If you are going with a igh volume pump, you will ikely want to get a larger than stock pan, so the oil pump does not run "dry"...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #4 of 5 (permalink) Old Oct 13th, 09, 07:23 AM
Brandon
Stock will work, but if you can dime it get a nice street/stip pan with baffles and windage tray.
71 Chevelle 496 Stroker Hyd Roller 675HP, TH400 3500 Stall, 3.73 12 Bolt.
ATK HP ENGINES
Custom Built Street-Strip-Racing Engines
Notalent is offline
post #5 of 5 (permalink) Old Oct 13th, 09, 11:49 AM
What I used, http://www.champpans.com/index.cfm?e...ctdetail&id=80
TC # 349
zdld17 is offline
