3.4l - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 13th, 09, 04:37 PM Thread Starter
3.4l
I have a 1993 base camaro w/ 3.4l v6. I had the car looked at and it had a bad coolant sensor . i replaced it and it ran fine for a little bit now it wont start. Before it would run really good then after awhile it would rev up andf idle at about 3k, if i give it gas it just dies no missing or anything just dead. if i let off before it gets to low then it will go back to 2-3k. it stalled and now it wont start. i have brand new wires, plugs, TPS, and coolant sensor. what in the heck could be wrong??
darkpit is offline
post #2 of 2 (permalink) Old Oct 13th, 09, 07:31 PM
Re: 3.4l
check to make sure the wires on the temp sender aren't crossed- it's easy to do when you change the sensor, and will cause the ecm to think that it's cold all the time and run super rich after it warms up.
you don't plan sincerity.
novaderrik is offline
