What cam for street 454? - Page 2 - Team Camaro Tech
post #16 of 18 (permalink) Old Oct 27th, 09, 02:30 PM
greg
Re: What cam for street 454?
Comp 282S 236-236- would work well in your combo and have better low end than the comp 280 hydraulic and will pull 15-16" of vacuum lashed at .022. Nice street cam with lots of low and mid range and won't beat up your valve train. Old school is cool and works!!
docwilcar is offline
post #17 of 18 (permalink) Old Nov 8th, 09, 03:56 AM Thread Starter
Nathan
Originally Posted by Straight-line-69 View Post
What tranny? Do you plan to swap rear gears soon to the 3.55's? Before you do that, you may want to consider a whole new rear-end. The original 40 year old 10-bolt isn't up to the task of 400+ HP.
Power brakes? A/C? Street and strip? Street only? Weekender or daily transportation?
Give us a few more details and you'll get some good advice.
Sorry for the delayed response, i've been away....The car has power brakes, stage 2 TH350, no A/C, street only. I will put a posi in the 10 bolt until I build a 9" diff. 12-bolts don't come up for sale in Australia....
MANUss427 is offline
post #18 of 18 (permalink) Old Nov 8th, 09, 04:00 AM Thread Starter
Nathan
Thanks for the recommendation. I am definitely going solid...and tossing up between the CC282s and Lunati 402A2Lun.
I have noted that Harold normally recommends non-symmetrical lobe designs too, which most Comp Cams seem to be?
I think it should go close to 500hp. I use 98ron petrol as its readily available.
