427 Truck Engine? - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 26th, 09, 08:14 AM Thread Starter
Clint
427 Truck Engine?
A person local to me says he has two 427 engines for sale. He says they were truck motors. Are these motors any good and would they make a nice engine for a 69 Camaro? Are they considered big blocks? If they are a good motor to use, what would they be worth? The block casting #s are: 364779 & 473478. Any information on these engines would be helpful.
Thanks,
Clint
cwb90 is offline
post #2 of 6 (permalink) Old Oct 26th, 09, 08:34 AM
Re: 427 Truck Engine?
364779 1968-88 366 tall truck
473478 1968-84 427 tall truck
Both are "tall deck" engines; you should be able to search here and find out about the fitment issues when using tall deck big blocks.
Eric
Eric Kammerer is offline
post #3 of 6 (permalink) Old Oct 26th, 09, 08:36 AM
Thanks,
Clint
Clint,
Casting info is as follows............
364779.....366T......68-90...4-bolt
473478.....427T......77-90...4-bolt
Most people tend not to build truck engines for car use because of fitment problems with headers and carburetor/intake manifold clearance issues with the hood. That's jmo.
David F,
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #4 of 6 (permalink) Old Oct 26th, 09, 12:37 PM
The 427 truck motor is not worth the time, trouble, and money you will invest. The 366 is a boat anchor
boonstein is offline
post #5 of 6 (permalink) Old Oct 26th, 09, 12:44 PM
Rich
The tall deck bigblock has a deck height that is about 1/2" taller then a standard bigblock.It can be used to make a good street or race engine.They are all 4 bolt mains and have very thick deck surfaces.The internals use the same crank and rods as a standard deck 427,but the pistons are really tall and have 4 rings on each piston.You could build a regual 427 out of it buy using high performance 427 pistons and aftermarket .400" rods,but the tall deck engine is best suited for a stroker buildup.Using the compact rods that are available today,it may be possible to put a 4.5" crank into it and with a .100" overbore it would be a great way to build a huge engine on a low budget,and the long stroke combo will make for a good street engine.Let me know how mch he wants for theem,if I can get my hands on one I might buy it.
RichSchmidt is offline
post #6 of 6 (permalink) Old Sep 29th, 15, 11:54 AM
ERV
i got a 473478 T4 engine build up to 511 short block,steel rods if interested is for sale i got it was part of a deal a made,if interested call me at 305-586-4048 or email [email protected] i will send more info and pictures
vallejomx is offline
