3.5 year old race gas?? - Team Camaro Tech
post #1 of 22 (permalink) Old Nov 4th, 09, 01:48 PM Thread Starter
Nick
Rarerat's Avatar
I just drained about 6 gallons of 3.5 year old VP out of the tank of my 68 SS/RS. I had hurt the car out at the track in March of 2006 and it has been sitting ever since. The gas still smells good (love that race gas smell) and I am considering dumping it into my 69 Z. What do you guys think? Think it might still be good? Or should I just dump it?
Thanks in advance,
Rarerat is online now
post #2 of 22 (permalink) Old Nov 4th, 09, 01:58 PM
Todd
Re: 3.5 year old race gas??
I'd discard of it....
Vegas69 is offline
post #3 of 22 (permalink) Old Nov 4th, 09, 02:29 PM
Find some fire ants to dump it on.
Probably won't be good for the car or the ants for that matter.
sspecialk is offline
post #4 of 22 (permalink) Old Nov 4th, 09, 02:43 PM
Brett
I doubt they have fire ants in New Mexico!
Brett
gm torch red is offline
post #5 of 22 (permalink) Old Nov 4th, 09, 02:54 PM
jason
i had 10 yr old race gas in a 55 gallon drum, wondered the same thing. smelled good pumped some into a bowl burned good. put it in my 68z smelled great and ran better, i say go for it.
68z28sd is offline
post #6 of 22 (permalink) Old Nov 4th, 09, 03:03 PM
Steve69SS396's Avatar
If the gas was still in the original sealed container it would be fine. Since it has been sitting in the fuel tank of your car for 3-1/2 years, just use it in your lawn mower or similar device.
Steve69SS396 is online now
post #7 of 22 (permalink) Old Nov 4th, 09, 03:17 PM
I'd mix it with some good gas and try it.
68 Camaro~LSx ~all motor
post #8 of 22 (permalink) Old Nov 4th, 09, 03:37 PM
Fred
Yep, try it. Toss a small amount on a gravel patch and light it. It should go 'Voom'. If that's not clear, compare to known good gas. But if it smells good, I'd run it in my 69. Also, my car sat for 3.5 years while I was rebuilding our sailboat. Turned the key, let the FI pump prime and it fired instantly and ran perfectly. If it smells good I'm sure it is good.
128.79mph 1.428 60'
Fred Ficarra is offline
post #9 of 22 (permalink) Old Nov 4th, 09, 04:35 PM
Ken
I agree, if it still smells good use it. I took a whiff of mine today and it still smells like the day I put it in the tank ( 4 months ago). If you're not sure you can always put it in a container and put the fuel line inlet in the container and see how it runs. Without dumping the entire fuel in the tank. I bet the 302 will love it! Heck, with the price of racing fuel these days, it's worth a shot.
_________________________
1969 Camaro
KMG69 is offline
post #10 of 22 (permalink) Old Nov 4th, 09, 04:44 PM
Jerry R.
jr68's Avatar
Why then do we put fuel stabilizers in our gas tanks for the winter ?
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #11 of 22 (permalink) Old Nov 4th, 09, 05:04 PM
Will
I would rather use 3 1/2 year old race gas verses 6 month old regular gas.
Hatman is offline
post #12 of 22 (permalink) Old Nov 4th, 09, 05:06 PM
X2
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #13 of 22 (permalink) Old Nov 4th, 09, 05:44 PM
Fred
So the stabilizer companies can make a living. Just look at the bottled water industry.
128.79mph 1.428 60'
post #14 of 22 (permalink) Old Nov 4th, 09, 05:44 PM Thread Starter
Nick
Rarerat's Avatar
Thanks guys, I think I may put a little in the lawn mower and it it fires up then I will dump the rest in the Z.
Thanks Again,
post #15 of 22 (permalink) Old Nov 4th, 09, 05:48 PM
Kevin
SixtyAte's Avatar
Because race fuel is $9.00 a gallon here and Stabil is 3.25 to treat 25 gallons
I actually just got some 100 Octane AV Fuel and mixed it 100 Race Fuel for the winter. I put 4 gallons of each in then 4 gallons of 94 octane Sunoco and just add more as needed. If the weather is above 60...I take the car out otherwise I just pull it out of the garage and let it run a while.
Kev
SixtyAte is offline
