Oil pan gasket leak on new engine? - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 11th, 10, 12:29 PM Thread Starter
Maybe have 20 miles on it and it is already leaking oil, see pic:
What are my options here? I have tried tighten the bolt some but that did not help. Do I need to change the whole gasket out? How hard is it to change the gasket with the engine installed? Thanks
1969 Camaro SS
Black Z is offline
post #2 of 8 (permalink) Old Jan 11th, 10, 05:24 PM
Re: Oil pan gasket leak on new engine?
Are you sure its the pan gasket?
Could be coming from above, (intake or valve covers)
BrewHog55 is offline
post #3 of 8 (permalink) Old Jan 11th, 10, 06:20 PM
Ron
It is not uncommon for Pan Gaskets to leak after a new rebuild, especially if you use an aftermarket or one that has be torched modified. Looks like you have the Fel-Pro Thick Blue Rubber Pan Gasket with the metal core - Excellent choice.
To verify the leak - Clean the area with a degreaser like Mean Green and hose off. Place the front of the car on Jack Stands and run the engine - you should spot the leak.
While the engine is cooling loosen and Re-Torque ALL the Pan Bolts. The Pan will Shape and eventually seal. I doubt if you will have to follow this procedure more then once but it has happened.
You will have slightly more Crankcase Pressure before the rings are seated. As Don states - look at other sources for leaks and your PCV System is working.
This was my 70 1/2 Z28
Z15CAM is offline
post #4 of 8 (permalink) Old Jan 11th, 10, 06:33 PM
george
Cork and rubber here with a little silicone in the corners=dry.
I have no luck with the one piece blue fel pros..they all failed at the timing cover/pan interface due to excessive crush that lead to splitting.Differant pans and covers..still the same.Seems like the gasket thickness up front is to thick by .125".
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #5 of 8 (permalink) Old Jan 11th, 10, 07:32 PM Thread Starter
Positve it is the pan gsket. I cleaned it twice already and it appears in the same spot. Should I do one bolt at a time, unbolt then retorque or loosen all bolts then retorque as I go around the pan? Should I try to put some more RTV sealant in that corner?
1969 Camaro SS
Black Z is offline
post #6 of 8 (permalink) Old Jan 12th, 10, 01:28 AM
Ron
When the pan is warm loosen the end bolts at the corners then start in the middle alternating side to side - loosen one at a time and re-torque working your way to the 4 corners. Once done repeat the sequence.
The purpose is to stretch and flatten the entire Pan Interface as that corner may be warped.
A quarter inch ratchet with extensions should do the job - don`t be afraid to make sure it`s tight but watch that you don`t flatten the gasket or dimple the pan bolt bosses.
You should not require a sealer, but if after 2 processes and it still leaks, you will likely have to split the seal and clean thoroughly with a De-greaser and Lacquer Thinner. Do not use Silicon - use RTV or Form-A-Gasket Compound applied with a Thin Flat Edge (like a Feeler Gauge).
When initially installing a pan I dab RTV at the obvious 4 locations where the Timing Chain Cover and Rear Main Cap intersects; however, before this I apply a thin film of RTV on the Rear Main Saddle and Rotate the Rear Main Seal about 1 quarter inch with a dab of RTV on the tips. I use the torquing procedure described above and repeat it several times before installing the engine.
Aftermarket and altered pans usually require re-torquing after the engine has run in order to stretch the warps out.
Z15CAM is offline
post #7 of 8 (permalink) Old Jan 12th, 10, 10:13 AM Thread Starter
Should I drain the oil to do this? Also what is the torque spec for the pan bolts? 8-10 ft lb?
1969 Camaro SS
Black Z is offline
post #8 of 8 (permalink) Old Jan 12th, 10, 07:09 PM
Steiner
With all that RTV on it it may never seal without cleaning it all off. New RTV will not stick to old RTV. Also, RTV is not rated for use on rubber gaskets.
I had the same type leak on the front of mine with a one piece seal. I used Permatex 2B non hardening to fix it. I wound up jacking the motor up, removed all except the back two bolts which I only loosened, pulled the pan down, cleaned the rail with brake cleaner, cleaned out the bolt holes with q-tips soaked in brake cleaner, smeared Permatex 2B all the way across the front lip, put Permatex 2B on the bolts, and reinstalled all of them.
I can't remember but it seems like the small bolts get around 10 ftlb and the four large ones get 13 ftlb. The one piece gasket has inserts to keep you from deforming the lip by overtightening....up to a point.
'69 Camaro
500hp/538lbft
Steiner is offline
