Whats Your Fastest Time With A Hydraulic Flat Tappet Cam. - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 12th, 10, 03:29 PM Thread Starter
RAFAEL
Hi all. I was just wondering how much power can someone get out of a hydraulic Flat Tappet Cam on a SBC. How many of you were able to get into the low 12's 11's or even 10's... I would really like to know.
Post your setups if you don't mind:
Which cam?
Engine displacment?
Heads?
Compression ratio?
Car?
Car wieght?
Gear ratio?
Trans?
Stall?
Carb size?
Intake?
And anything else you you like to list. If you run a solid flat tappet you can post you setup too also. Thanks guys....
LAZR_GUIRA is offline
post #2 of 7 (permalink) Old Jan 13th, 10, 08:51 AM Thread Starter
RAFAEL
Re: Whats Your Fastest Time With A Hydraulic Flat Tappet Cam.
FUNNY.... No body has a HOT Flat Fappet Hydraulic cam Set up. Ohwell
post #3 of 7 (permalink) Old Jan 13th, 10, 09:12 AM
Which cam? Lunati 20102
Engine displacment? 353 CID
Heads? Crane Fireball
Compression ratio? More than 1:1
Car? The correct year - '68
Car weight? 3100#
Gear ratio? 4.11
Trans? The best Powerglide
Stall? 3500 rpm
Carb size? 750 CFM
Intake? Holley 300-36
[email protected] MPH. Now my secret is out.
post #4 of 7 (permalink) Old Jan 13th, 10, 09:58 AM
Brett
Which cam? lunati 00012
Engine displacment? 355
Heads? GM BOWTIE
Compression ratio? 10.25:1
Car? 67Camaro
Car wieght? 3,200
Gear ratio? 4.10
Trans? Turbo 350
Stall? 2,800
Carb size? Holley DP 700
Intake? Edelbrock Victor Jr.
Mid 12's/ 11.92 with nitrous. This was back in 1985.
Brett
gm torch red is offline
post #5 of 7 (permalink) Old Jan 13th, 10, 12:15 PM
Rich
[email protected] .3600# car 439 inch bigblock,blow blended iron GM rectangular heads,Crane 310-2 nc cam,266/[email protected] 600/620 lift 850 carb,team G intake,3.5" race flowmasters.powerglide with 5000 stall and trasbrake and 4.56 gears with 30" tall tires.Engine was running way past the cam at about 7600 in the lights.Oh and I forgot to mention a 200hp shot of nitrous from the 60 foot mark on down:0 car runs 10.40's at 127 on motor with 4.88 gears.I can tune the nitrous to about 400 hp,but I would need to drop the gear a lot more.It might go 8.90's.The car currently has a stock GM .560 lift cam and runs 10.40's on motor,but I havent shot it yet.
[email protected] A 355 small block with mildly ported stock heads,an Isky 292 mega cam,a 144 super charger{7psi boost},a 250 shot of nitrous in a 3100# 80 malibu.Swapped in a solid flat tappet and spun it to 7200,only made 4psi of boost,and went 9.96 @133 .3500 stall convertor 3.73 gears then 4.10 gears
12.0 @111 3400# car{same car as the first one}355 smallblock,11:1 compression,ported camel hump heads,and strip dominator intake,750 doule pumper,1 7/8" headers and 3.5" flowmasters.TH350 trans with 3500 stall,4.10's with 30 inch tall slicks.on motor,was going thru the traps at 7200 at the end of 2nd gear.{it went slower when I shifted to 3rd.Cam was a solid flat tappet,255/262 @.050,518/536 lift,106 seperation.All on motor and pump gas.
RichSchmidt is offline
post #6 of 7 (permalink) Old Jan 13th, 10, 12:27 PM Thread Starter
RAFAEL
Thats funny... Don't worry your secret is safe with me
Thanks for stepping up to the plate guys. Keepem coming
post #7 of 7 (permalink) Old Jan 13th, 10, 12:41 PM
Okay, Thanks, I forgot to put 750 CFM Vac Sec.
