Need a bellhousing and what clutch ? - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 13th, 10, 09:02 PM Thread Starter
Jake
I have a 406 little M block being built .
9.5 to 1 afr's 195 forged crank 6"rods
need a bellhousing and clutch for it
trans will be a muncie/autogear m22w
I am a tile mechanic not a car mechanic
so any help is great
THANKS
Jake 69 is offline
post #2 of 7 (permalink) Old Jan 13th, 10, 11:45 PM
Jess
Re: need a bellhousing and what clutch ?
Are you going to drag race? Street and Strip. I would do a 621 with a 11 inch clutch... I am old school though...
Jess67
67 Camaro Blue 427, 4-speed, 12 bolt
67 Camaro 350, 200-4R, PS, AC, PB, IN PARTS
Jess67 is offline
post #3 of 7 (permalink) Old Jan 14th, 10, 05:22 AM
Camarodude67
You could just use a 403 Bellhousing and zoom/centerforce clutch, as stated before street or racing?
Jeff G.
69 Verts.
camarodude67 is offline
post #4 of 7 (permalink) Old Jan 14th, 10, 09:07 AM
I did the same with a 621 housing , but CFII single disc clutch and plate with a billet flywheel.
TC # 349
zdld17 is offline
post #5 of 7 (permalink) Old Jan 14th, 10, 05:29 PM Thread Starter
Jake
I am bidding on a 621 bellhousing on ebay, but I dont know what kind of clutch to use for it, I know i need an 11 inch and a 168th tooth flywheel.
Will be used for 95% street and a couple runs at raceway park, just to see what kind of times I can get. What are your thoughts about a scattershield opposed to a bellhousing? do you think it needs it? (425hp, 450 torque)
thanks
Jake 69 is offline
post #6 of 7 (permalink) Old Jan 14th, 10, 05:31 PM Thread Starter
Jake
I hear good things about Mcleod clutches
Jake 69 is offline
post #7 of 7 (permalink) Old Jan 14th, 10, 06:02 PM
Re: Need a bellhousing and what clutch ?
Yes, Mcleod is good. Didn't think of this 10 years ago when I bought the CFII for my Tri Five, switched to 700R and didnt think it would last in my camaro, sure fooled me, been there for 8 years now. I just change discs when everything is apart. .
TC # 349
zdld17 is offline
