Do water pumps squeal? - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 14th, 10, 12:39 PM Thread Starter
G`day all my 67 small block 327 has started making a loud high pitched squealing sound. It does not make it when the engine is cold only once it has warmed up and goes away if I increase the revs but then comes back. It is extremely loud and can be heard from around 100 feet away.
I am thinking water pump bearing or impella, had anyone had a similar problem?
Thankyou in advance
sad67 is offline
post #2 of 6 (permalink) Old Jan 14th, 10, 12:41 PM
BILL
SPARKY69's Avatar
Re: do water pumps squeal?
loosen the belt or take it off the water pump and spin the pulley by hand to see if you feel it grinding while you turn it or see if you have play in it, rock it back and forth...also could be the water pump belt out of adjustment or a worn belt?
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #3 of 6 (permalink) Old Jan 14th, 10, 12:42 PM
Vintage 68's Avatar
Wink Re: do water pumps squeal?
They do when the main bearing is about to fail
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 6 (permalink) Old Jan 14th, 10, 12:59 PM
Steps
And when the main bearing is worn "about to fail" generally the seal on the end leaks or there is a leak from the small breather hole underneath the waterpump in between the fins.
to check if it is the belt, pour water on the belt and see if the squeel stops temporarally.
Steptoe is offline
post #5 of 6 (permalink) Old Jan 14th, 10, 03:37 PM Thread Starter
Sorry I forgot to post that I checked all the belts first by spraying them with a belt dressing lubricant and that didn't stop the squealing.
Thanks I will drop the belts over the weekend and see if its the water pump.
The guys on this Forum "ROCK"
sad67 is offline
post #6 of 6 (permalink) Old Jan 15th, 10, 08:55 AM
Mickey
Moonpie's Avatar
Re: Do water pumps squeal?
Sounds like the bearing, man!
Moonpie is offline
