L92/LS3 cam that is a for a driver - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 14th, 10, 08:16 PM Thread Starter
Patrick
Any good cam recommendations for the above? It will never see a strip or a track. Looking for something that will idle and have a light lope but still tons of low end torque.
My last motor had such a radical cam the plugs would get fouled every 100 miles. I don't want to go there.
I was told the Hot cam from the GM Ls6 is good
Also a read that a grind from Delta cams in Tacoma? part#157-238-250
Thanks!!
1968 Convertible L92 VVT project, Hotchkiss lowering front & rear.
68problemchild is offline
post #2 of 2 (permalink) Old Jan 14th, 10, 08:35 PM
Re: L92/LS3 cam that is a for a driver
Thanks!!
I would run to LS1tech.com and either read or post a question there.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
