82 350 - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 14th, 10, 08:33 PM Thread Starter
corey
82 350
Hey guys,I have a bit of a problem and was wondering if you could help. I ust put a new comp cam in, and new lifters . I just finished breaking in the cam . Iam wondering the car almost boggs when you rev the car fast , and idles a bit rough , it almost sounds like it was not running on all 8 cylinders does this seem like a tunning issue or somthing else
steps350 is offline
post #2 of 6 (permalink) Old Jan 14th, 10, 09:35 PM
Smile Re: 82 350
You didn't mention the "type" of cam. Hydraulic, solid, or roller ? It could be your lifter adjustment, it could be timing, it could be wrong wires on cylinders. (firing order)... we need more info.
TJS69 is offline
post #3 of 6 (permalink) Old Jan 14th, 10, 11:39 PM Thread Starter
corey
Re: 82 350
oh sorry , its a hydraulic flat tappet comp cam not sure the duration on its nothing extream , its got the comp hydraulic lifters
steps350 is offline
post #4 of 6 (permalink) Old Jan 15th, 10, 09:23 AM
Smile Re: 82 350
You might have tightened your rocker arms to tight. You can adjust them with the car running. It is messy ! Oil goes all over ! Use lots of rags ! Loosen each rocker until you here a ticking sound. Tighten rocker arm until noise stops, and then tighten 1/2 turn. Go on to next rocker (lifter).
Also recheck your timing. Are you still running the computer controlled distributor and carburetor ?
TJS69 is offline
post #5 of 6 (permalink) Old Jan 15th, 10, 10:56 AM Thread Starter
corey
Re: 82 350
ok thanks for all the help i will do that today, oh I dont no if this belongs here or not but I have the msd street fire ditributer it has a tach port on so I ran my wire from my tach to it but some timesthe tach will just stop working any idea why?
steps350 is offline
post #6 of 6 (permalink) Old Jan 16th, 10, 01:08 PM Thread Starter
corey
Re: 82 350
hey all thanks for the help I adjusted the rockers , some of them were pretty over tightened , so I just want to say thanks
steps350 is offline
