Oil change frequency - Team Camaro Tech
post #1 of 31 (permalink) Old Jan 15th, 10, 08:33 PM Thread Starter
Peter
If expense is not a issue, how often do you guys change your oil and filter, not the 4wd or the shopping trolley I mean the pride and joy
502 BB, TKO600
69aus is offline
post #2 of 31 (permalink) Old Jan 15th, 10, 08:39 PM
DONNIE
Re: Oil change frequency
i do mine every 7,500miles i use amsoil in my 96 ss probley do the same with the 67 but it will sit more so once a year on that one
"Well, the trouble with our liberal friends is not that they are ignorant, but that they know so much that isn't so." -- Ronald Reagan
67CAMAROSS is offline
post #3 of 31 (permalink) Old Jan 15th, 10, 09:12 PM
Dana
Every 25 passes.
RSCopo is offline
post #4 of 31 (permalink) Old Jan 15th, 10, 09:30 PM
AJ
In the daily driver, when the gauge reads "0"
In the camaro, it's kind of like when you can tell if someone messes with the thermostat in the house... 2,000miles? Just bought $50 worth of mobil1 synthetic even with a discount, so this will prob last over 3k and a year.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 31 (permalink) Old Jan 15th, 10, 09:41 PM
red
2 times a year. Early in season and about 3/4 through summer.
red67L78 is offline
post #6 of 31 (permalink) Old Jan 15th, 10, 09:43 PM
Dale
I preach changing oil when it starts to change color.
68 Dana 302, 68 rs 327 daily driver/family car, 71 rs, track car/ driver, 68 firebird 400, 70 formula 400, 73 type LT, 98 TA, 2 goofy kids and an incredible wife.
dale68z is offline
post #7 of 31 (permalink) Old Jan 15th, 10, 11:00 PM
Todd
In a daily driver do it by intervals. In a hot rod, do it by the dipstick. If it starts to get dark, change it.
Vegas69 is offline
post #8 of 31 (permalink) Old Jan 16th, 10, 06:31 AM
Kevin
KevinW's Avatar
7,500 thereabouts for the 04 chevs and once a year for the Camaro (but there is very old oil in the Camaro now because it has been in the shop for a long time. Gotta change the trans and rad first, then change the oil before I fire it up again (in the spring )
Kevin
KevinW is offline
post #9 of 31 (permalink) Old Jan 16th, 10, 06:46 AM
Andrew
Andrew69's Avatar
4,000 to 5,000 miles for the daily drivers. The owner's manuals say go longer, the oil change companies (who want your money) say ~ 3,000 miles.
Once a year for the Camaro, which translates to less than 1,000 miles between changes.
I still change my own oil on all the vehicles.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #10 of 31 (permalink) Old Jan 16th, 10, 08:30 AM
Take a look in the archives, and you will find some past discussions from tscamaro and Dave Nelson on this very topic...on Nov 29/09.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #11 of 31 (permalink) Old Jan 16th, 10, 08:38 AM
Fred
77thor's Avatar
My 69 Camaro gets changed once a year, just before storing in fall... but I only put 1000 miles/year tops....
77thor is offline
post #12 of 31 (permalink) Old Jan 16th, 10, 10:50 AM
click's Avatar
Once a year with Amsoil 100% syn and Amsoil's nano-fiber, special oil filter. This is my procedure with all my cars, Tahoe, Maxima, 69 Camaro too. 35 years using this oil, never a problem.
click is offline
post #13 of 31 (permalink) Old Jan 16th, 10, 10:59 AM
"Tri-Tip"
Gary L's Avatar
My Camaro only sees 2000-2500 miles per year right now. I change it once a year, but always get it hot by driving when I start it up. I don't want a crankcase full of condensation.
Gary L is offline
post #14 of 31 (permalink) Old Jan 16th, 10, 02:48 PM
winter or after a day at the track.
68 Camaro~LSx ~all motor
post #15 of 31 (permalink) Old Jan 16th, 10, 04:32 PM
gary
Your supposed to change the oil?
pro70z28 is offline
