427 cam up grade - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 15th, 10, 11:14 PM Thread Starter
Dwight Nelson
427 cam up grade
Hi everyone new to site been watching for awhile. So here is my question i have a 69 rs/ss with a 454 in it with a 427 crank wanting to up grade my cam from a comp 284/296 574/578. Its great off the line but is lacking on top end . I'm want more top end wanting to up grade to a solid maybe with about 630 lift.Which way do u think i could go that would help me go faster. thanks
69the only kind is offline
post #2 of 9 (permalink) Old Jan 16th, 10, 08:41 AM
Dana
Re: 427 cam up grade
Welcome Dwight. You are probably going to have to give us some more info on your engine. Do you want just change the cam, or will you be going thru the entire engine?
RSCopo is offline
post #3 of 9 (permalink) Old Jan 16th, 10, 09:41 AM
Yes, as stated, need more info on the motor.
Heads, Intake and carb, Compression also, whats the part # on the current cam, or full specs?
1967 RS/SS 396 4 Speed (All Stock)
Journey is offline
post #4 of 9 (permalink) Old Jan 16th, 10, 08:11 PM Thread Starter
Dwight Nelson
Thanks for the response i am going to change the cam and i will probaly have to upgrade the converter and all the other things that go along with the cam. I have a 454 block with a 427 crank with a bore of .60 with brodix alumi heads with srp pistons i am told that it was to make about 450-475 hp . I was wanting to bring it up to about 550. Just wondering what i would have to do. Thanks Guys
post #5 of 9 (permalink) Old Jan 16th, 10, 08:16 PM
AJ
Really need to know what the compression ratio is, this is determined by piston, head gasket thickness, piston in the hole, head chamber size in cc's.
What are you going to do with the car, street, street/strip, strip.
100hp is a big gain for just a cam, you will probably be looking at a solid roller.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #6 of 9 (permalink) Old Jan 16th, 10, 09:37 PM Thread Starter
Dwight Nelson
my compression ratio is 11.1. thanks for the info. 50 more hp would be great also. Trying to run street and strip, and play with some of the corvette's and viper's that think they own the streets. Thanks
post #7 of 9 (permalink) Old Jan 16th, 10, 09:46 PM
AJ
11:1 is a great ratio, you can build a lot of power and aren't very limited in selecting supporting mods. just gonna throw this one out there http://www.summitracing.com/parts/CCA-CL11-772-8/
skip had a pretty strong running 427 before the 496, maybe he could chime in on his old cam specs, I don't remember if it was a roller or not, but I would highly suggest a roller, especially a solid.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #8 of 9 (permalink) Old Jan 17th, 10, 11:21 AM Thread Starter
Dwight Nelson
Thank u ace's 68 i have a buddy that has a 434 with a comp cam with about the same lift and he has great power and good street manners that is what made me want to change my set up. i currently running a flat tappet with 574 lift in that range it gives me great starting power but not much on top end. By the way i have a holley 830 4150 series. Thanks
post #9 of 9 (permalink) Old Jan 18th, 10, 08:24 PM Thread Starter
Dwight Nelson
Ok guys here is the plan as of now removed the heads yesterday and will take them down to brodix and have them flowed and let them tell me the best cam to use in order to get the most performance out of them. I really thank u for all your info. it was very helpful
