Any tips on removing intake manifold? - Team Camaro Tech
post #1 of 23 (permalink) Old Jan 16th, 10, 09:05 PM Thread Starter
Nev
Started to remove the intake manifold today (or tried at least)
I cannot get this manifold to budge (Yes, I have removed all the bolts), so I have walked away for a while before I do something I regret.
At the moment I'm thinking of bolting an engine lift plate to the manifold and gradully lift with the engine hoist.
Anyone got any tips to break a stubborn intake mainifold free?
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
post #2 of 23 (permalink) Old Jan 16th, 10, 09:12 PM
Jeremiah
Re: Any tips on removing intake manifold?
Drive a putty knife between the intake and head to break the bond.
Its probably a million to one chance but as a precaution I would suggest staying away from the corner tabs of the manifold.
69 Z/28, red/white stripe, black houndstoot with docs.
Jeremiah is offline
post #3 of 23 (permalink) Old Jan 17th, 10, 06:13 AM
Dan Ensign
Stupid question but did you remove the distributor?
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #4 of 23 (permalink) Old Jan 17th, 10, 07:09 AM
foreverlookin's Avatar
Go around the intake with a putty knife take your time and it will break loose.
foreverlookin is offline
post #5 of 23 (permalink) Old Jan 17th, 10, 07:44 AM
Jeff
yellow69RS's Avatar
I've often driven a screwdriver into the end seal at the front of the block on iron intakes, I'd have to think of someting else for aluminum or plastic.
Jeff
yellow69RS is offline
post #6 of 23 (permalink) Old Jan 17th, 10, 11:58 AM
Fred
Yep, some kind of prying device. Divide and conquer. Start at a corner. Tap the bar into the joint. Do it slowly and pry slowly so as to not score sealing surfaces. With any luck the manifold wasn't installed with super glue.
128.79mph 1.428 60'
Fred Ficarra is offline
post #7 of 23 (permalink) Old Jan 17th, 10, 02:20 PM
A bigger lever.
post #8 of 23 (permalink) Old Jan 17th, 10, 02:37 PM
Bill
Nev,
There is always someplace on the intake that you can get a big screwdriver in an pry a little. It wont take much, once it breaks loose it will come right off. I would definitely not do the engine lift thing, it might work but when it pops loose you will be sorry
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #9 of 23 (permalink) Old Jan 17th, 10, 03:22 PM
prostreet69camaro's Avatar
Wood hammer handle in the thermostat housing where the hose connects. Slowly hit the hammer with the palm of your hand in the up position.
prostreet69camaro is offline
post #10 of 23 (permalink) Old Jan 17th, 10, 08:06 PM
Keith
Depends on what it was installed with...I know when I put my manifold on, being uninformed and fearing any kind of leak, I used the brush on permatex gasket stuff--I'm pretty sure it IS super-glue...hopefully I don't have to pull the manifold, EVER!!!
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #11 of 23 (permalink) Old Jan 17th, 10, 08:19 PM
Todd
I just removed mine that I had glued on wih silicone. That baby was stuck. I'd drive a flat screw driverbetween the block and intake and it will come loose. It takes more force than you think. I wouldn't risk the gasket surfaces.
Vegas69 is offline
post #12 of 23 (permalink) Old Jan 18th, 10, 03:55 AM
AJ
The screw driver method has worked for me in the past, put it on the end of the block and into the galley. Don't get too rough with it as you may scratch or scar the valley ends.
I like the idea of the mallet on the thermostat housing or tapping around the intake a little near the plenum, shouldn't hurt it.
Don't put the screw driver or whatever you use near the head/intake sealing surfaces.
If you did the engine hoist thing with it in the car, and it's really stuck, it could pop up and dent the hood?
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #13 of 23 (permalink) Old Jan 18th, 10, 11:36 AM
Todd
You seal the ends with silicone anway, if they get boogered up a little it won't hurt. If the intake is glued on tapping the housing and around the base plate won't work. Tried that.
Vegas69 is offline
post #14 of 23 (permalink) Old Jan 18th, 10, 06:25 PM
Kip
I shouldnt admit it... but... I once used a hydraulic round hay bail stabber which was attached to my fathers 1 ton pickup and a chain to remove an intake that was particularly stubborn... I thought I was gonna lift the car off of the ground before it let loose!!! Ahhh..... Youth....!!!
kv67ssrs is offline
post #15 of 23 (permalink) Old Jan 19th, 10, 05:08 AM
Brent
Brentmc's Avatar
Run a razor blade along the front and rear of the intake to slice throught any sealant in those areas. Then run the razor blade along the sides of the intake to break the seal on the sides.
Find a spot where a flathead screwdriver or putty knife will get under the intake on the sides and pry it up and off.
1968 RS/SS Lemans Blue
Brentmc is offline
