69 coupe exhaust hanger clamps - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 17th, 10, 09:04 AM Thread Starter
bigsteve
Should the exhaust hanger clamp use for the rear muffler to pipe connection also be used for the under body exhaust hanger mount?
bigsteve is offline
post #2 of 7 (permalink) Old Jan 17th, 10, 11:48 AM
Fred
Re: 69 coupe exhaust hanger clanps
Big, not sure what you're doing, but here is the only hanger used on the system except for the ones at the edge of the wheel well. This is original before and after cleanup.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 7 (permalink) Old Jan 17th, 10, 12:01 PM Thread Starter
bigsteve
I have the hanger bolted like you do , its the clamp that goes on the other end...does 1 clamp do the hanger and clamp the muffler to the pipe or should I use 1 clamp for hanger and another for the muffler to ppe connection.
bigsteve is offline
post #4 of 7 (permalink) Old Jan 18th, 10, 08:44 AM Thread Starter
bigsteve
Can anyone answer this question?
bigsteve is offline
post #5 of 7 (permalink) Old Jan 18th, 10, 08:52 AM
mark
mark x22's Avatar
if your asking if one clamp can hold the pipe joint and hanger because the joint is under the hanger yes
mark x22 is offline
post #6 of 7 (permalink) Old Jan 18th, 10, 04:12 PM
Keith
I have the same hangers on my new exhaust--same clamp to hang and clamp the tailpipe to the muffler...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #7 of 7 (permalink) Old Jan 20th, 10, 04:00 PM Thread Starter
bigsteve
Re: 69 coupe exhaust hanger clamps
Thats it..thanks!
bigsteve is offline
