Good SB Rotating Assembly - Team Camaro Tech
post #1 of 20 (permalink) Old Jan 19th, 10, 03:39 PM Thread Starter
What is a good SB rotating assembly that is rated under 500hp (good value)? Just got word from the machine shop that my 4-bolt checked out and is ready to go. Not even going to fool with original crank and rods!
1968 RSSS BB 396/325 AC TH-400 Black/Red (Sold)
1969 Nova SS 350 M-20 Red/Black (Original)
1967 Chevelle SS (Clone)(Project)
tim68rsss is offline
post #2 of 20 (permalink) Old Jan 19th, 10, 04:25 PM
Steve69SS396's Avatar
Re: Good SB Rotating Assembly
What are you building, 350, 383?
Steve69SS396 is offline
post #3 of 20 (permalink) Old Jan 19th, 10, 05:09 PM
Eagle or Scat
68 Camaro~LSx ~all motor
post #4 of 20 (permalink) Old Jan 19th, 10, 05:53 PM Thread Starter
350 bored .030 and decked .010 with modified stock heads alum intake with 670 Holley Street Avenger.
post #5 of 20 (permalink) Old Jan 19th, 10, 05:54 PM
Banned
If your looking gor a good rotator the Callies Compstar crank rods and Mahle pistons is top of the line and so far been pretty happy with thier product.
CNC BLOCKS N/E is offline
post #6 of 20 (permalink) Old Jan 21st, 10, 05:49 PM
TJ
i have forged eagle crank with eagle h-beam rods and forged ross racing pistons
z28kid is offline
post #7 of 20 (permalink) Old Jan 21st, 10, 06:32 PM
AJ
If you want to save some $ for other parts, Scat is really good quality from what I hear, I've heard some negative stuff about Eagle, but I know of a 355 with eagle internals that runs really well. Callies is good as mentioned, ross, mahle, probe, kb, are all good pistons, depends on price and quality.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #8 of 20 (permalink) Old Jan 21st, 10, 08:02 PM
Bill
Tim,
How much do you want to spend ? That really is gong to determine what to buy.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #9 of 20 (permalink) Old Jan 21st, 10, 10:54 PM
Butch
Agree 100% (Also Scat 4340 and Scat Rods are good for the money spent) unless he is looking to save every penny
If he is looking to save every penny a Scat Pro Comp Cast crank and Scat I Beam Pro Comp Rods are great, should set him back $550-$600 for both crank and rods and can handle some descent HP
Originally Posted by BillK View Post
Tim,
Hey Bill, didnt know you were over here too. Your a busy guy counting work
href="
target="_blank">www.prosystemsracing.com
trmnatr is offline
post #10 of 20 (permalink) Old Jan 22nd, 10, 07:06 AM
I also used the Callies package Carl is talking about and am very happy
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline
post #11 of 20 (permalink) Old Jan 22nd, 10, 01:06 PM Thread Starter
Either of these ok?
http://www.summitracing.com/parts/SCA-1-92205/
http://www.summitracing.com/parts/ESP-B13402E030/
Anyone know if Summit or Jeggs has any discount codes at this time?
post #12 of 20 (permalink) Old Jan 22nd, 10, 01:09 PM
AJ
Hyper pistons are okay, but I'd opt for forged.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #13 of 20 (permalink) Old Jan 22nd, 10, 01:31 PM
BILL
SPARKY69's Avatar
get a gm steel crank
eagle rods
je/srp pistons.0280 dome(10.5-1)
weiand team g intake
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #14 of 20 (permalink) Old Jan 22nd, 10, 03:55 PM
Banned
eagle rods
GM don't even make the 1182 forged crank any more.
post #15 of 20 (permalink) Old Jan 23rd, 10, 08:08 AM
Scat, Compstar & Srp.
TC # 349
zdld17 is offline
