Engine frame mounts - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 19th, 10, 05:13 PM Thread Starter
aj
Engine frame mounts
i've read 1,000 posts and am still trying to find the heights for the 2 different sb mounts. i have a 327 in a '69 that wont line up with my frame mounts. my frame mounts are about 2 1/8" tall. i think taller ones would work. just want to make sure before i order them since i can't find any locally
akada39 is offline
post #2 of 13 (permalink) Old Jan 19th, 10, 05:14 PM Thread Starter
aj
Re: engine frame mounts
car had no motor or frame mounts when i got it
akada39 is offline
post #3 of 13 (permalink) Old Jan 19th, 10, 06:01 PM
Aj try this link has helped me
http://www.camaros.org/engine.shtml#EngineMounting
regards dave
aussie68cam is offline
post #4 of 13 (permalink) Old Jan 19th, 10, 07:00 PM
Smile Re: Engine frame mounts
Which engine mounts do you have ? The tall and narrow or the short wide ? Your engine mounts must match your frame mounts. If you are trying to use mounts from Autozone, thier books are not right.
TJS69 is offline
post #5 of 13 (permalink) Old Jan 20th, 10, 05:54 PM Thread Starter
aj
motor mounts are 2267, which matches '69 327. i think the frame mounts are for a 302. they are 2 3/8" wide
akada39 is offline
post #6 of 13 (permalink) Old Jan 20th, 10, 07:34 PM
I would get new engine mounts for a 302/350. They bolt on your 327 with no problems. The 302/350 frame and engine mounts will allow you to run an 8" harmonic balancer. The 327 mounts will not allow this. The engine mount Anchor part number is 2285.
TJS69 is offline
post #7 of 13 (permalink) Old Jan 21st, 10, 05:45 PM Thread Starter
aj
my 8" balance is sitting on the sway bar now and the mounts are not even all the way on yet. aren't the 327 mounts taller
akada39 is offline
post #8 of 13 (permalink) Old Jan 21st, 10, 06:30 PM
No, The 69's 302/350 engine mounts are called "Tall and narrow" and the 327 are called "short and wide" for a reason.
TJS69 is offline
post #9 of 13 (permalink) Old Jan 23rd, 10, 02:26 PM
dan
danimaldds's Avatar
Since we are on the subject, is their a difference in the mounts from a early model 350 to a 87 or higher 350. The reason I ask is I put a crate motor in the car for a while and the headers on the driver side seem to close to the steering box. Are there different mount I should use? It had the stock motor before the change. Is the block that much different?
Dan
1969 SS 383 Stroker , TKO 600, 3:73
1964 vette conv. 327/ 300 freshly ,completely repainted. I mean everything!
danimaldds is offline
post #10 of 13 (permalink) Old Jan 23rd, 10, 06:40 PM
The engine mounts changed in the early 70's to a clam shell design. More than likely the '69 style mount was bolted to the 87 block. Many header's are close to or touching the steering box !
TJS69 is offline
post #11 of 13 (permalink) Old Jan 24th, 10, 06:17 AM Thread Starter
aj
motor mounts are from advanced auto. i bought a pair of 2285's. they're wider. i'll try 2283's. and i have some other frame mounts on the way
akada39 is offline
post #12 of 13 (permalink) Old Jan 24th, 10, 06:18 AM Thread Starter
aj
also, i think a long water pump would help alternator clearance, but a '69 pump looks short. any thoughts on that or what year motor water pump to use
akada39 is offline
post #13 of 13 (permalink) Old Jan 24th, 10, 09:49 AM
Your problem...is more than likely the wrong part in the correct box. The 2285's should be 2 3/8 wide the 2283 and 2267 are 2 5/8 wide. The 1969 water pump is a long water pump. 67-68's had the short pump. An '87 water pump may have been for a serpentine belt. Although it would be a long pump, it would be a reverse rotation.
TJS69 is offline
