angled plug headers - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 21st, 10, 08:35 AM Thread Starter
123
tom
angled plug headers
well finally decided to go with dart pro 1 iron eagle heads on a 383 should make around 450hp/450tq which headers is the next ? i recently ordered a 2 1/2" magaflow exhaust this car had no ps so i got an ididit tilt column an arg steering box moog pitmanarm also bought a va system and a march styletrack belt system and ordered a tko 600 just not sure on which headers to use any ideas
thanks tom
oh almost forgot it's a 67 rs/ss
123 is offline
post #2 of 3 (permalink) Old Jan 21st, 10, 09:05 AM
Re: angled plug headers
I used Dyna Tech headers, there stepped header 1 3/4 to 1 7/8. They fit great had no problems with the clutch linkage or the power steering box.
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears
mike's blue67 is offline
post #3 of 3 (permalink) Old Jan 21st, 10, 09:08 AM
Kevin
I have some of these same parts, except the heads. But I do have angled plugs on my 454 SBC (World block and heads). I also have PS and Vintage air and TKO 600. But due to higher HP, I use the a 3.5 collector on Hooker #2207-1. I don't know about your choice of 2.5 exhaust..why not 3" ? Your collector is going to be 3" I think, so I would run that much at least to your muffler, then maybe use 2.5" tailpipes if you want.
Before you buy, call the header manufacturer as they know how to read the tea leaves in their catalogs.
-Kevin
'68 RS Camaro, 454 SBC
'69 Camaro, body only
MissionCritical is offline
