Air Fuel Ratio at light cruise - is it problem? - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 21st, 10, 12:51 PM Thread Starter
Bill
Under light cruising down the hiway my wideband gauge can get into the high 15s to mid-16:1 range. No pinging and all seems to be runnin fine but wondering if I need to make an adjustment. If so, what would I be looking at doing? Thinking this would require larger sized primary jets?
I live at high altitude and commonly drive in 5,000 - 7,000 ft above sea level terrain so did jet the carb down a few notches from stock so possibly too much. Engine is ZZ383 and tranny is 5spd. - I'm cruisn between 50 - 70 mph at very low 2k rpm when this scenario occurs - not pressin the pedal very much.
68RS-SS is offline
post #2 of 5 (permalink) Old Jan 21st, 10, 01:16 PM
Rod
Re: Air Fuel Ratio at light cruise - is it problem?
just waiting to see I have my air/fuel gauge on my ride and would like to see about basic settings also with my new heads, great question!
Rodney
crazyshopmonkey is offline
post #3 of 5 (permalink) Old Jan 21st, 10, 01:59 PM
My stock QJ was pulling right around 15:1 with my LM-1 wideband on the highway at cruise and ran fine. I got it up as high as 18:1 as an experiment to see if my gas mileage would improve. It didn't, car ran hotter and surged. You may be fine where you are.
Melrose RS is offline
post #4 of 5 (permalink) Old Jan 21st, 10, 06:14 PM
About what I am pulling but at a 3500 ft level, been out your way to Clines corner , didn't have any issues.
TC # 349
zdld17 is offline
post #5 of 5 (permalink) Old Feb 2nd, 10, 12:38 AM
Steiner
My Street Avenger ran pretty lean like that at very light throttle and didn't seem to have an issue. I put some wire in the low speed air bleeds to downsize them and it got the ratio down some.
'69 Camaro
500hp/538lbft
Steiner is offline
