How much warp is too much in a flexplate? - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 21st, 10, 06:34 PM Thread Starter
Gary
I have been working through a shake in my engine for about 2 months, replaced just about everything ON the engine, that left me with only the flexplate and Torque converter. I took off the converter this evening to find the flexplate bent (warped/ wobbles) about 1/16-1/8".... the shake ALMOST completely dissapeared with the converter removed. I am thinking that the warp in the flex was magnified by the weight of the torque converter, plan to buy a new flexplate, does that sound like the right move to you guys?
67 RS style is offline
post #2 of 8 (permalink) Old Jan 21st, 10, 06:40 PM
Re: how much warp is too much in a flexplate?
Since you already have it apart that far and flexplates aren't terribly expensive, I say go for it. Could also be an out of balance converter. Describe "ALMOST"
BPOS is offline
post #3 of 8 (permalink) Old Jan 21st, 10, 06:43 PM Thread Starter
Gary
if the shake was on a scale of 1 to 10, 10 being most evident, it dropped from a 10 to a 1,, almost unnoticeable,, to the point at which I think I may just be imagining it due to the fact I saw the warped flex and can't get my mind off the issue, it has been driving me nuts and I want to solve the problem...
post #4 of 8 (permalink) Old Jan 21st, 10, 06:49 PM
Below is advice given by BowTie OD for inspecting...
Check it visually while the engine is running, if you can see visible for and aft movement, you
should check run out with a dial indicator. Factory tolerance is .030 total run out.
3. Cracks in the flex plate right around the crankshaft bolt circle are very common. Flex-plates are very cheap compared to
the time, effort and money required repairing the potential damage that will occur later if the flex-plate should fail or ruin
the transmissions front seal and bushing.
Clean 67 - 600hp / 579ft lb, 502
St Petersburg, FL
mccomas is offline
post #5 of 8 (permalink) Old Jan 22nd, 10, 10:58 AM
Bill
Re: How much warp is too much in a flexplate?
Gary,
If the shake went away when you unbolted the converter, then the converter is probably the issue. If the flexplate was out of balance, it would shake no matter what. To be honest with you, I have yet to see a stock type flexplate that is not warped at least 1/8" I have them bolted up on almost every single crankshaft I balance and believe me the only ones that are real true are ones from ATI, JW's "the wheel" and other thick flexplates. All of the stock ones have a little wobble in them. The ones with a weight welded to them (400 Chevy, SB Ford etc) are the worse. It does not hurt anything at all. If you think about it, once you bolt the converter up, it is straight.
You can try a flexplate if you want, but I would bet on the converter or something in the trans myself.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #6 of 8 (permalink) Old Jan 22nd, 10, 11:50 AM
Fred
Gary, Bill's the pro.
Think about why they're called 'flex' plate. Their job is to transfer power. They rely on the converter for stability. Check your converter/transmission.
128.79mph 1.428 60'
Fred Ficarra is offline
post #7 of 8 (permalink) Old Jan 27th, 10, 08:00 PM Thread Starter
Gary
I FOUND IT!!! after rebuilding the carb, changing the plugs, wires, distributor, then replacing the carb, the intake manifold, balancing the driveshaft, replacing the u-joints,, and ultimately seeing the warped flexplate,,, the shake went away after replacing the flexplate( mine was original from 1967 according to my trans guy), the torque converter, and the powerglide with a turbo 350... ya, the trans guys was quite a salesman...but the truth be told, I am thrilled, the car runs like a rocket, quick and smooth
post #8 of 8 (permalink) Old Jan 27th, 10, 08:21 PM
Dana
Glad you found it Gary. The good thing about finally figuring out a hard to find problem is once you do, after replacing/checking so many things, the cars always seems to run so good!
RSCopo is offline
