Where did you mount your MSD box? - Team Camaro Tech
post #1 of 21 (permalink) Old Jan 21st, 10, 07:39 PM Thread Starter
Trevor
I have ordered a MSD 6AL box and was curious of some of the places I can hide it, I have a smooth firewall so I want to keep it off there, Where are some of the other places it can safely go that has reasonable access, thanks.
1969 SS 454ci TKO 600
Alberta69SS is offline
post #2 of 21 (permalink) Old Jan 21st, 10, 08:11 PM
Re: Where did you mount your MSD box?
1967 Camaro - LM7, T56, TVS
1996 Impala SS - DD
Acidburn is offline
post #3 of 21 (permalink) Old Jan 21st, 10, 09:05 PM
Carl
I had mine on the firewall but have seen them mounted as above, in the jockey box and on the inner fenderwell.
chevguy65 is offline
post #4 of 21 (permalink) Old Jan 22nd, 10, 12:47 AM
Nev
Sorry, for what is probably a dumb question, but what's a "jockey box"?
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
nev68 is offline
post #5 of 21 (permalink) Old Jan 22nd, 10, 03:27 AM
Mine was on wheelwell... but now on the firewall.
68 Camaro~LSx ~all motor
post #6 of 21 (permalink) Old Jan 22nd, 10, 04:42 AM
BILL
SPARKY69's Avatar
69 camaro hidden behind glove box
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #7 of 21 (permalink) Old Jan 22nd, 10, 06:21 AM
Carl
LOL...no problem, I guess it's an old slang for glove box
post #8 of 21 (permalink) Old Jan 22nd, 10, 08:19 AM
Rich
Just for all you guys who mount it on the firewall.Here is the setup I did.As you can see,I made a little heat shield under the box for added protection from the headers wich can radiate a lot of heat when the car is sitting when the engine is first shut off.I also have my main battery junction right underneath it which is where the main power for the box comes from.If you look at my coil wire you can see that I moved the coil into the cowl box where the wipers normall go.If you hang the coil from the top of the box it wont get wet or get in the way of the wipers,but you would need to drill a hole in the firwall{and seal between the 2 layers of firewall.the coil and the box stay plenty cool which is one less thing I have to worry about.Most racers put the box on the floor in the passenger side interior,but I just wanted to keep it under the hood.On a car with fendewells,any area in front of or behind the wheel wells is a good choice for hiding the box.Good luck.
RichSchmidt is offline
post #9 of 21 (permalink) Old Jan 22nd, 10, 09:00 AM
Eric
I have my 6al mounted on theheater box in the pass side interior and my digital controls on a plate in side the glove box opening.
69 SS396 fathom green N/A525 833chrysler 4spd 3550# stock suspension 10.11/137mph
vonzipper396 is offline
post #10 of 21 (permalink) Old Jan 22nd, 10, 09:09 AM
class67's Avatar
I mounted mine right behind the drivers side headlight on the radiator support, out of the way and hardly noticable....
67 Camaro RS
class67 is offline
post #11 of 21 (permalink) Old Jan 22nd, 10, 09:16 AM
Brent
Brentmc's Avatar
Mine's in the wheelwell
1968 RS/SS Lemans Blue
Brentmc is offline
post #12 of 21 (permalink) Old Jan 22nd, 10, 09:35 AM
prostreet69camaro's Avatar
I have mine mounted under the passenger side dash on an aluminum plate. I also have the coil and extra fuse blocked mounted on the plate also.
For you guys that are going to say dont mount your coil on its side,, it has been like that for 15 years with no problems. Knock on wood.
prostreet69camaro is offline
post #13 of 21 (permalink) Old Jan 22nd, 10, 09:54 AM
Steven
I hung mine from the ash tray receptacle. It's invisible and stays clean.
sik68 is offline
post #14 of 21 (permalink) Old Jan 22nd, 10, 11:59 AM
Fred
As a guy who's had an MSD box die when mounted above the heater box, (OK, yeah, L88's will do that) it's been mounted in front of the radiator support for about 20 years. It gets lots of cool air. But, then again, ceramic headers are so cooooool, it's like the engine isn't even on. Maybe I'll find a reason to move it back. After all, mine's a RS. Na.
128.79mph 1.428 60'
Fred Ficarra is offline
post #15 of 21 (permalink) Old Jan 22nd, 10, 03:43 PM
I mounted mine under the pass seat with my timming control on a plate sandwitched between the seat and the floor ran the wires under the console and nobody knows. I can set in the drivers seat reach under and pull the chip out . Installed this way for 5 years with no problems .
ssdoug is offline
