How do you know if you need to shim a starter? - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 25th, 10, 07:24 PM Thread Starter
Tony
I'm putting a 302 in my 69. I've never had to shim a starter before and I'm not sure how to determine if it needs to be shimmed. Thanks very much!
Tony's '69 -
69RS/Z28 is offline
post #2 of 5 (permalink) Old Jan 25th, 10, 09:35 PM
Vic
Re: How do you know if you need to shim a starter?
Vic
1969 Camaro SS
Camaro1969 is offline
post #3 of 5 (permalink) Old Jan 25th, 10, 09:40 PM
Vic
the pinion to flywheel should be about .100 inch away, and u need a wire gauge of .04 between the pinion of the starter and your fly wheel, shim accordingly to meet these specs
Vic
1969 Camaro SS
post #4 of 5 (permalink) Old Jan 25th, 10, 11:02 PM
kt
kelly
Start without shims, MOST do not need shims, if it does it will let you know as it will sound odd when cranking.
kt is offline
post #5 of 5 (permalink) Old Jan 26th, 10, 04:49 AM Thread Starter
Tony
Thanks Guys! I appreciate the help.
Tony's '69 -
69RS/Z28 is offline
