427 Camshaft question/concern - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 26th, 10, 01:51 PM Thread Starter
Shon
I picked up a lightly used (150miles) 427 that was in a 69 yenko clone. It has a solid lifter cam and the top end is noisy. Through the guy i got the motor from, I was able to get from the engine builder only that it was the correct cam for a yenko 427, but he doesn't remember which cam. Is there a safe backlash setting i can use on the valves without knowing which exact cam i have. The motor was set up to run on pump gas 10:1 comp. It seems that .024 or .025 is common backlash. Any thoughts?
fasterweride is offline
post #2 of 6 (permalink) Old Jan 26th, 10, 02:32 PM
BILL
SPARKY69's Avatar
Re: 427 Camshaft question/concern
I would of guessed .028??
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #3 of 6 (permalink) Old Jan 26th, 10, 02:33 PM Thread Starter
Shon
.028 good for intake and exhaust.
post #4 of 6 (permalink) Old Jan 26th, 10, 02:34 PM Thread Starter
Shon
That was a question, sorry.
post #5 of 6 (permalink) Old Jan 26th, 10, 04:35 PM
george
If its an L72 camshaft, it calls for .020" intake...024" exhaust at operating temp.With an all iron big block..add .002" to each for a safe cold lash setting.If it has aluminum heads..subtract .004" from the hot setting.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #6 of 6 (permalink) Old Feb 1st, 10, 07:39 PM Thread Starter
Shon
Just remembered, Guy said it was 390hp. I can't find info showing a solid lifter cam for 390 hp. Anyone?
