What carb is on a 1967 210hp 327? - Team Camaro Tech
post #1 of 11 (permalink) Old Jan 26th, 10, 08:33 PM Thread Starter
Seth
I need to rebuild or replace the carb in 1967 Camaro with a 210HP 327. Anyone have a reliable source for these, or know a reliable rebuilder? The car is all original so idealy I would like to rebuild. Any advice is greatly appreciated.
SehtT is offline
post #2 of 11 (permalink) Old Jan 26th, 10, 08:44 PM
Lane
Re: What carb is on a 1967 210hp 327?
Rochester dualjet, you might try http://www.carburetorexchange.com/plp/search.php
Lane
rlyfst1 is offline
post #3 of 11 (permalink) Old Jan 27th, 10, 02:34 PM
greg
cliffshighperformance.com He is the man for quadrajets, even has a book on how to rebuild the q-jet.
docwilcar is offline
post #4 of 11 (permalink) Old Jan 27th, 10, 03:04 PM
AJ
The 327/210 before building a new motor used what looked like a 2bbl Q-jet and probably was, protect-o-plate said it was a "bay city" carb, don't know if there is a difference, maybe tuning, jets, and so on...
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #5 of 11 (permalink) Old Jan 27th, 10, 03:19 PM
Vintage 68's Avatar
Wink Re: What carb is on a 1967 210hp 327?
Hummm - these were two barrels, not Q-jets
It would have been equiped with a Rochester 2GV.
These pre-68 units are often refered to as 'small base' due to a smaller base without a couple of additions on the 1968 and later bases.
It used a 'divorced' choke assembly with the termo/bi-metalic spring actuator mounted on the intake.
The application number for the carb will vary depending on the engine equipment, smaog device(s) installed and type of trans.
I would recommend the Carb Shop - http://www.thecarburetorshop.com/
They have an excellent supply of cores and can build and tune the carb you need for you.
1968 Convertible
Some trucks
Vintage 68 is offline
post #6 of 11 (permalink) Old Jan 27th, 10, 03:29 PM
AJ
OOPS, your right, I did in fact mean Rochester, got the brand and the models mixed up.
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
post #7 of 11 (permalink) Old Jan 27th, 10, 07:38 PM
Gary
I just pulled this system off of my car ( the two barrel 1968 code) and the intake. If you are interested, drop me a note, it is for sale. I just rebuilt the carb about a weeks prior to pulling it off the car. I thought the carb was causing a shake, turned out to be the torque converter after replacing the carb, the distributor, the plugs, wires, intake manifold pretty much everything..I planned to build a new motor so I was working that way anyway but got there sooner because of the stupid shake.. now its gone, I figure the carb is about $195 rebuilt from one of the places mentioned above, and the intake similar price but we can work something out.
67 RS style is offline
post #8 of 11 (permalink) Old Jan 27th, 10, 07:39 PM
Gary
I can even hook you up with the kick down linkage for the 2bbl
post #9 of 11 (permalink) Old Jan 27th, 10, 07:46 PM
Gary
just realized you wanted to rebuild YOUR 2bbl,, sorry got my hopes up.. anyway, I got my kit from the carb doctor carburetor.ca they are in canada, cost was $37 to my door and I got it in about 3 days, of course, my carb is already rebuilt and only been on the bench for about 2 weeks so if you don't want to mess with rebuilding, just let me know an we can make a deal
post #10 of 11 (permalink) Old Jan 27th, 10, 09:46 PM
JAY
Almost any good parts store will have kits, floats, ect for your carb.
I used a local rebuilder to do my card on 66 SS. My throttle shatfs were worn out and he drilled out base and installed bushing to repair
working good now and no problems at all. most of the in-box reman
carbs are JUNK! My friend bought 5 Holly-2 carbs before he got a good one and it had a whole 90 day warranty...lasted about a year
Jay
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
post #11 of 11 (permalink) Old Jan 27th, 10, 10:46 PM
AJ
local parts store should have everything you need, gaskets, etc...
'68 333" Camaro
'14 5.0 Mustang
ace's68 is offline
