Starters: 350 vs 400? - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 27th, 10, 12:25 PM Thread Starter
Is there a difference in a starter for a 400 small block and a 350? I replaced an old style starter with an aluminum mini-starter and have gone through two of them without much if any use. I know the flywheel is from a 400 (383ci), but I had presumed all sbc starters were the same. I am wondering if this may be my problem?
Your help always appreciated!
Jason
1968, 383, 700R4, Convertible
Southtwnr is offline
post #2 of 6 (permalink) Old Jan 27th, 10, 12:33 PM
Re: Starters: 350 vs 400?
There were two different flywheels (flexplates) as far as tooth count goes - 153 and 168 - and each requires its own starter. You need to determine how many teeth your flywheel has and get the correct starter for it.
BPOS is offline
post #3 of 6 (permalink) Old Jan 27th, 10, 01:06 PM Thread Starter
Ive been told that auto transmissions use the 168 count. I also have the staggered bolt pattern which I have been told should be 168 count. I havent counted the teeth, but that is what I have been basing my purchase on.
Thanks for the reply!
Jason
post #4 of 6 (permalink) Old Jan 27th, 10, 02:20 PM
Auto trans can be 153 or 168 just like manual trans. My auto uses a 153.
I've heard lots of good and lots of bad about the mini starters. You might do a search and see which brand people have had good luck with. I personally like the old original style starter with the brace installed at the front.
BPOS is offline
post #5 of 6 (permalink) Old Jan 27th, 10, 04:03 PM
Steps
This is a component that looks as if it is not very important, do not under rate its effect.
Something not mentioned too often in starter motor threads, maybe should be?
Steptoe is offline
post #6 of 6 (permalink) Old Jan 28th, 10, 06:52 AM Thread Starter
I got under the car and examined the flywheel after replacing my starter(under warranty). Sure enough I found a broken tooth or two. I dont know if it is a cause or a result, but it looks like a new flywheel is in my future. I do have some flywheel questions, but I will start a new post for those.
The starter I am buying is based on 2000 Tahoe, 5.7Liter, Auto transmission. Any thought on how many teeth are on those flywheels? I am going to investigate a little more.
